RC Electric Off-Road Trucks, Buggies, Truggies and more Discuss electric RC off-road, buggies & trucks here. Also discuss brushless motors, speed controllers aka ESC's, brushed motors, etc
vintage team associated RC 10
Reply
Old 07-16-2010, 11:15 AM
clhuke64
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default vintage team associated RC 10
I'm new to RC cars and just picked up a vintage team associated RC 10, I'm looking for a set of rear shocks and assorted other parts. Is there any other Team Associated models that inter change with the vintage RC 10 ?? ie; use another models shocks on the vintage ??
Thanks for the help
clhuke64 is offline
Old 07-16-2010, 11:24 AM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: vintage team associated RC 10
Yes, nearly everything on the vintage rc10 can be found on other associated cars (unless you need parts for the 6 gear transmission). The shocks used on the rc10 are the same used on the b2,b3, and b4 (with the exception of the b4 front shocks, which are a little longer). The model numbers all stayed the same for interchangeable parts. You can get on the associated website, download the manual, look for the part numbers and enter the on towerhobbies.com. Tower carries just about every associated part ever made.
proanti1 is offline
Old 07-17-2010, 05:51 AM
skyraider71
skyraider71's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I own two "gold tub" cars, a six gear and a stealth car. The shocks are not exactly the same, there are some differences in the early cars.
skyraider71 is offline
Old 07-17-2010, 09:12 AM
skinned
skinned's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
e bay has shocks for that all the time...[8D]
skinned is offline
Old 07-17-2010, 11:15 AM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: skyraider71
I own two ''gold tub'' cars, a six gear and a stealth car. The shocks are not exactly the same, there are some differences in the early cars.
Same length, the only difference is the circlip on the bottom of the shock holding the o-rings in instead of the top loaded clip system and the gasket instead of the o-ring used to seal the shock cap. I would love to find me some NOS 6 gear shocks...
proanti1 is offline
Old 07-17-2010, 08:31 PM
skyraider71
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I wish I could get those clips out of mine, does anyone have a tip for this?
Old 07-17-2010, 08:54 PM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I use these. It has to be a set of internal circlip pliers. I got mine at lowes.
http://www.knipex.com/index.php?id=1...5&groupID=1457
You basically have find some pins that fit in those little holes and figure out how to squeeze them together. Its very easy to mess up that little plastic retaining ring though.. and you are pretty much screwed if you do, they are nearly impossible to find. They also use a larger size o-ring than the normal AE shocks which can also be a pain to find.
proanti1 is offline
Old 09-16-2011, 06:03 PM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proanti1
I bought two vintage "A" stamp RC10s. I also bought two sets of the front shocks back in 1985 to compliment my Tamiya Frog's CRP front shock upgrade parts and rear end.
skyraider71 is correct - and you are not correct.
dragnse7en is offline
Old 09-17-2011, 06:31 AM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: dragnse7en
Quote:
ORIGINAL: proanti1
I bought two vintage ''A'' stamp RC10s. I also bought two sets of the front shocks back in 1985 to compliment my Tamiya Frog's CRP front shock upgrade parts and rear end.
Did you see the part where I explained the difference between the A-stamp shocks and the later model Team shocks?
proanti1 is offline
Old 09-17-2011, 11:36 AM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proanti1
Did you ever buy any of these? The construction and assembly and parts are different. Yes, I read your description, and I think that you should carefully double check the facts 1st.
I'm sorry, but you're still wrong.
Old 09-18-2011, 05:02 AM
proanti1
proanti1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proanti1
Ok. The guy had a question about compatibility, shock length. The length between the early rc10 shocks and the team rc10 shocks is the SAME. The ONLY physical difference between the two styles is the body, how the o-rings load in through bottom and are retained by a clip. He wanted an answer about something that would work, I gave him one. Someone else came in and pointed out that there was a difference between the two styles, I clarified. I have owned more 6-gear rc10's than I care to remember.
proanti1 is offline
Old 09-18-2011, 07:36 AM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh.
Well, then, there you go!
Je vois.
Old 09-18-2011, 07:52 AM
QSR1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
MY RC Truck will take
7.2V Ni-MH
8.4V Ni-MH
or 7.4V lithium polymer
What is my best option for power and run time as far as upgrade?
What brand is usually the best?
QSR1 is offline
Old 09-18-2011, 08:03 AM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
A lipo battery will have the longer run time against a nimh, hands down.
As far as brands go, that's a personal preference. Go to hobbypartz dot com to get insane deals on lipo hardcase packs.
Old 09-18-2011, 11:06 AM
QSR1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Awesome, thanks
QSR1 is offline
Old 10-11-2011, 05:55 AM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proanti1
You're still wrong. The earlier shocks used were 0.56 fronts and 1.02 rears, and the team cars used the 0.71 fronts and the 1.32 rears.
Please refer to this link, so that I may back up my point:
www.teamassociated.com/pdf/cars_and_trucks/RC10/CE/cat_rc10.pdf
Note that the legend says d and e are the Team and world car kits. Now look at the bottom column on page six.
You should really do your homework, Proanti1. I grade you with an F for the false advice
Old 10-11-2011, 04:41 PM
chonyc77
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: proanti1
Wow Proanti1, this guy really knows his stuff. He got you on this one. Lol
chonyc77 is offline
Old 10-13-2011, 05:45 PM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have no ill-will against Proanti1. He's a good guy that means well, but obviously doesn't know AE as well as I do in my 26 years in this rc hobby
He's a good guy though, don't get me wrong!
Old 10-14-2011, 08:09 AM
littleVETTE
littleVETTE's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
1.02" rears? that's new to me. i always thought ALL aluminum tub/graphite rc10's came with 1.32" shock bodies in the rears.
littleVETTE is offline
Old 10-14-2011, 08:30 AM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's what it says on the AE web site. I think that's wrong too, but the A stamp cars' shocks are shorter than the worlds and team cars' shocks. That's apparent enough.
Old 10-14-2011, 10:03 AM
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: littleVETTE
1.02'' rears? that's new to me. i always thought ALL aluminum tub/graphite rc10's came with 1.32'' shock bodies in the rears.
ThunderbirdJunkie was under the impression that 1.32s didn't come around until the 10T.
ThunderbirdJunkie is offline
Old 10-14-2011, 10:23 AM
dragnse7en
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My original 10T came with 1.02 fronts and 1.32 rears, so maybe
Reply
Display Modes
