Slash 4x4 or SC10 or Blitz?
Narrowed it down to three short course vehicles. What do you guys think I should get? Im leaning toward the slash 4x4 since i have a slash 2wd that I like and seems to run okay for me on the track. This shortcourse would be strictly for racing btw. Thanks in advance.
Moderator
RE: Slash 4x4 or SC10 or Blitz?
If you want 4x4 then obviously go with the Slash, of the other 2 I prefer the SC10. I've driven both and like the way the AE one handles better.
ORIGINAL: mval9188
Hyper 10SC-Novak HV PRO 6.5t sensored combo.
Slash 4WD- stock.
HPI BLITZ-VXL 3500kv combo.
Slash 2WD-Xcelorin 4800kv motor/Sidewinder ESC.
Savage Flux-stock.
Factory brushless E-Revo.
NY
ORIGINAL: mval9188
If you were comparing just 4wd, or 2wd, trucks it would be one thing. But it's not fair to compare one company's 4x4 against other company's 2wd models, it's not a fair fight.
IL
ORIGINAL: topdogg11
Defintely choose either a Slash or the Blitz. These two are made DURABLE enough to at LEAST not break while removing them from the darn box when you first buy it!! The Slash and Blitz will not only survive breakage from just pulling it out of the box, it will also take almost ANYTHING you can subject them too!!
ORIGINAL: mval9188
CA
take the blitz. it has better handling than the slash, and is ALOT more durable than the sc10. the blitz is like taking alot of good things from the slash and alot of good things from the sc10 and fusing it into one truck, which is the hpi blitz. the tires are also very cool, so is the body if you get teh ART series, not the maxxis. the chassis is pretty darn durable, too. idk, JMHO
OH
For 4wd SCT, pass right by the Slash 4x4. It's weak. SCRT10 is the way to fly.
For 2wd SCT, Get a Kyosho Ultima SC-R, Blitz ESE, or SC10 Factory Team...make your decision based on what is most popular at your track so you have setup support locally and what your local hobby shop supports for parts. A local guy has been running his SC-R for a few months and hasn't broken anything.
If you are ONLY racing, you likely already have electronics to drop in the truck, and RTR grade electronics just don't cut it for heavy abuse that these trucks see.
The Slash is not indestructible, either...had an impact with one tonight that left it disabled. That truck is at LEAST as modified as ThunderbirdJunkie's SC10.
No, Traxxas hires people that spell "definitely" properly.
ORIGINAL: Eman77
You a Traxxas employee? Yeesh.
ORIGINAL: topdogg11
ORIGINAL: mval9188
id reccomend either the hpi blitz ese or the factory team sc10.
Both are really nice.
Id go with the blitz ese if it were me as it has a hardened steel ball diff, no worries of melting it and it is tough.
ALSO it looks MEGA nice in the grey/white scheme. It has lots of nice hop ups on it that you dont find on other sc trucks.
Alloy shocks set which is 140 right there,
then theres the ball diff(with ceramic nitride balls)
full race tuned plastics,
alloy motor mount heat sink set,
cvd set
titanium turnbuckles and top shaft
alloy ball studs and locknuts
well worth your money
