brushless
My Feedback: (8)
RE: brushless
I wouldnt use the vxl esc.
The best parts of that combo is the castle motor and that high kv is just about useless except for speedruns in a buggy or touring car.
RE: brushless
ORIGINAL: burnineyes
Don't even consider 4s in this truck, I will assume the person who recommended that was thinking you have a 1/8th or a monster truck.
ORIGINAL: Sal Bandini
The 8.5T combo is ideally suited for the Firestorm/Rustler/Desert Truck/Stampede/Slash trucks.
I can't see anyone not being more than happy with this in their trucks.
there's a reason I have a 1/8th motor and 4s in my firestorm, because there's no way I'd be happy with that combo!
#31
ON, CANADA
RE: brushless
No buddy, you just like to brag that you have some gear shredding stupid power house, that cant put power down. You dont need 4s, and you dont need 1/8th scale motor either, a properly geared 1:10th scale on 3s will push 70mph, you dont hit 60 i bet
#32
OH
RE: brushless
Redvanmafia doesn't understand how KV+big motor+big gearing works.
The bigger the motor, the taller the gear you can run.
The lower the KV the higher the voltage you can run.
The lower the KV the taller the gear you can run.
See where ThunderbirdJunkie is going with this?
#36
RE: brushless
ORIGINAL: Redvanmafia
now I'm running a bigger motor and 4s.
so, whats this about me not hitting 60mph ya dumbass?
#39
AB, CANADA
RE: brushless
just checking my options
ORIGINAL: ThunderbirdJunkie
Is this guy serious?
ORIGINAL: yoyo5
could i use the 1-cell esc with the 6900kv or the 7700kv
#40
AB, CANADA
RE: brushless
Im going to get the mamba max 5700kv combo from my lhs. but i need help from you guys to help my pick a good cheap 2s pack for it and a charger
#41
IL
RE: brushless
ORIGINAL: yoyo5
http://hobbyking.com/hobbyking/store...dProduct=10098
charger:
http://www.hobbypartz.com/thac6smbachw.html
#42
My Feedback: (8)
RE: brushless
ORIGINAL: yoyo5
http://www.hobbycity.com/hobbycity/s...idproduct=8357
or battery
http://www.hobbycity.com/hobbycity/s...idproduct=9435
In my opinion a good charger is a important purchase. Make sure you get acharger that has all the features and charge rates your going to need.
Charger is alsosomething I would spend a little money on and be worry free. This will be my next and last charger for a long time.
http://www.dynamiterc.com/Products/D...ProdID=DYN4064
Chargers I have owned.
http://www.hobbycity.com/hobbycity/s...idProduct=7898
Works good but only at 2.5 amps. Can charge 2 (2s) packs at one time
Duratrax onyx 230, good charger but you have to use a external balancer
Dont forget deans,ec3 or xt60 connectors for your batterys and esc.
#43
RE: brushless
I'm guessing the 5700 is the stock motor,
I wouldn't get it, its very wrong for the vehicle, they overheat easily, and are quite slow.
anyone that disagrees with this doesn't have a clue, and hasn't tried a proper motor.
#44
AB, CANADA
RE: brushless
theydontwantmusic it's the sidewinder that is stock. also i went to my lhs and the don't have it in stock and don't plan on geting it but the do have the dynamite fuze system for 120$ and it's 5800kv would this work
#48
RE: brushless
5800kv is TOO MUCH FOR YOUR TRUCK.
If your ESC is still good, buy a 3000-4000kv motor and plug it in and go.
Maybe he will listen this time.
