RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Electric Off-Road Trucks, Buggies, Truggies and more (http://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/)
-   -   27mhz and 29mhz (http://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/6427785-27mhz-29mhz.html)
straty 09-29-2007 06:49 AM
27mhz and 29mhz
Hi i have a sanwa reciever and i need a new transmitter the crystals are 29mhz as with the reciever is it possible to use a 27mhz transmitter with the 29mhz crystals
thanks in advance
Straty
ohgrfreak 09-29-2007 07:00 AM
RE: 27mhz and 29mhz
Crystals should come in two packs, one for the receiver and one for the transmitter, you should use the same frequency crystal in both.
TIGER76 09-29-2007 08:50 AM
RE: 27mhz and 29mhz
the rx and tx need to be the same frequency to work
as freak said they should come in a pack of 2 from a LHS;)
mindwreck 09-29-2007 01:18 PM
RE: 27mhz and 29mhz
same frequency and channel on the receiver/transmitter and crystals if you want everything to work out correctly
straty 09-29-2007 07:14 PM
RE: 27mhz and 29mhz
i know the crystals need to be the same but can i use a transmitter labled 27mhz with a 29mhz reciever
hands without shadows 09-29-2007 07:22 PM
RE: 27mhz and 29mhz
Quote:
ORIGINAL: straty
Not unless you remove the filters from the receiver, and then you can expect mass glitching when anyone else is running between 24mhz and 30mhz. RC car receivers don't come in 29mhz; do you have a link to your receiver?
ohgrfreak 09-29-2007 07:27 PM
RE: 27mhz and 29mhz
I thought it was just AM, FM and 2.4ghz and the crystals tell you the actual frequency (unless you're using 2.4ghz). You won't happen to be using a wal-mart-esque R/C car, would you?
straty 09-30-2007 01:35 AM
RE: 27mhz and 29mhz
no i have a losi xxx-t running a sanwa reciever
mtbkym01 09-30-2007 01:45 AM
RE: 27mhz and 29mhz
What you want to hear is no you cannot use a 27mhz transmitter with a 29mhz reciever. I'm assuming your reciever is quite old, as I also have 29mhz gear in my on road tourer, which I used to use back in the late 80's. If your having trouble finding a new transmitter, you may need to get a new reciever also, and switch to 27mhz.
