RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Electric Off-Road Trucks, Buggies, Truggies and more (http://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/)
-   -   fastest brushless motor (http://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/6945439-fastest-brushless-motor.html)
DriftingDragon 01-21-2008 04:10 PM
im looking for the fastest 540 or 550 brushless motor any ideas is it just the dynamite 9200kv or is there faster?
pede_187 01-21-2008 04:14 PM
RE: fastest brushless motor
The 9200 is for 1/18. Do you know how many cells or any?
BanditMonster 01-21-2008 04:26 PM
3.5r Novak or 5700 Mamba on 3s li-po are probably the fastest 540 sized brushless with a practical number of cells and not something ridiculous like 16-20 cells.
crawlerking11 01-21-2008 04:33 PM
mambas are really fast i have one for sale in the classifieds http://www.rcuniverse.com/market/item.cfm?itemID=360548 its a 7700 kv and it can run on lipos its as fast as youlll want to go cuz when ur going that fast a small mistake can turn into a huge mistake if ur interested just post it on the ad
DriftingDragon 01-21-2008 04:41 PM
im gunna be sticking it in the new emaxx how does the Tekin R1-Pro Mod 290 BL System preform
Access 01-21-2008 04:51 PM
Fastest would have been Nic Case's Neu, I think it was a Neu 1509 or a Neu 1110, unless something has beaten Nic's record.
DriftingDragon 01-21-2008 04:58 PM
ORIGINAL: Access
ok well except that way too expensive i also need an esc
dirt101 01-21-2008 05:04 PM
in an emaxx your best bet is going to be an 8xl if you want reliability, or if you just want all out speed you can go with an 7xl.
Access 01-21-2008 05:05 PM
He was using a castle creations phoenix-HV 85 on that car I think.
DriftingDragon 01-21-2008 06:05 PM
so would the tekin ones be any good?
and is there any way to water proof a brushless esc or any that are waterproof?
DriftingDragon 01-21-2008 06:39 PM
im thinking this Novak Electronics HV High-Voltage Brushless 4.5 ESC with Team Orion Vortex Brushless Motor 4.5 would this work?
sloppyG 01-21-2008 06:42 PM
why would you try and put a touring car motor in an emaxx?
DriftingDragon 01-21-2008 07:01 PM
ORIGINAL: sloppyG
i honestly didnt know that it mattered? so should i go for the whole hv4.5 system and would there be any way to make a "vtwin" with it?
DriftingDragon 01-21-2008 07:10 PM
how bout this 1 4.5 DUO 550 MONSTER TRUCK MOTOR TRAXXAS E-MAXX
dirt101 01-21-2008 07:17 PM
im telling you a feigao is much better suited for the emaxx. 550 is barely big enough for a rustler, emaxx needs an XL can to run without overheating.
DriftingDragon 01-21-2008 07:33 PM
but which 1 should i use iwant the whole thing to cost 250 max
dirt101 01-21-2008 07:38 PM
I personally would either go with an 8xl or 9xl to be safe.
Do you know what esc your going to use?
Batteries? what kind of batteries your using makes a huge difference on which motor you should choose
DriftingDragon 01-21-2008 07:46 PM
Takedown 01-21-2008 07:59 PM
You can run Novak Velocity motors at 80k rpms because of the strong sintered rotors. If you run a 5.5r on 3s it will give you 82140rpms. That rpm limit is unloaded so as long as your pinion stay securely on the shaft and that your motor doesnt move away from the spur I think you'll have one helluva fast motor.
DriftingDragon 01-21-2008 08:00 PM
for now it would just be running on 2 7 cell 8.4v
dirt101 01-21-2008 08:01 PM
Do you already own that esc or did you just pick it out? if your looking for an esc the Mamba max is a better choice, but you will have to run a BEC, or a receiver pack with it.
DriftingDragon 01-21-2008 08:03 PM
i picked it cause i can run 2 8.4vs on it
DriftingDragon 01-21-2008 08:05 PM
ORIGINAL: DriftingDragon
i dont have alot of money to get lipos and charger
sloppyG 01-22-2008 12:49 AM
you can get an adapter to run 2 packs in series on the mamba max for about $11
it's a good esc for a monster truck
j.m. 01-22-2008 05:58 AM
c'mon!!!!!
You need TORQUE, not speed! THAT is what will make your e-maxx fast. How about using this:
http://www.rcuniverse.com/forum/m_25...tm.htm#2587132
and seeing what size pinion you'll need to use the 3.5r (i bet they don't make one)
