vxl motor, mamba esc on 4s?
i have ordered a 4s lipo and i am doing this anyway i just
need to know if anyone has done it. yes i searched it, i spent lastnight researching before i bought the battery's. it will be going in either a 1/10 stadium truck or buggy. im sure the battery will have no problem but im thinking the speedy might let go. if anyone has actually run this i would like to hear what happened. i was goin to do a 6900 on 3s but a 3500 (vxl) on 4s might not have the top speed but it should be plenty powerful [>:] and not work as hard to get the power. i saw some videos of this but they were all doing speed runs. yes i have run it on 3s, yes i know how powerful it is. i have a 7700 mamba and i used to like going fast and having a fast truck. now i want more volts, lower speed and savage-dog like power. has anyone done this? cheers. |
RE: vxl motor, mamba esc on 4s?
I don't personally understand how you're going to get all that power to the ground. A 2WD stadium truck won't have the traction to actually use all that power, I can barely control the slash w/ vxl on 3S and don't even bother doing it anymore. I just run 2S batteries.
But in reference to your question, I've never done it before and have absolutely no inclination to do so. |
you can a 7700 motor on a 1/10 st truck on 3s? ouch what were the temps?
but no i havent done it.. just split the packs and make 2 2s packs |
ORIGINAL: Druss I don't personally understand how you're going to get all that power to the ground. A 2WD stadium truck won't have the traction to actually use all that power, I can barely control the slash w/ vxl on 3S and don't even bother doing it anymore. I just run 2S batteries. But in reference to your question, I've never done it before and have absolutely no inclination to do so. the lug |
The mamba max will handle up to a 2600 XL motor on 4S with an external BEC. I have a VXL powering my 8B with a 2800KV motor on 3S. I have an external BEC and I will be trying it on 4S with a 2100KV Losi motor to see what happens. I dont think it will blow unless you over draw it with a crazy KV motor. They will both smoke. Its a pretty beefy ESC and its rated for 100amps.....I'll keep my fingers crossed.
Here it is with the 6XL motor but the 2100 on 4S will be happening soon. http://i157.photobucket.com/albums/t...5/IMG_5027.jpg |
im surprised that vx esc hasnt let go yet.
nice buggy? sorry if its not a buggy [:@] the 7700 and the 6900 dont use on 3s. my lipo caught fire from it. to much draw. dont do it. yes getting the power to the ground or not getting to the ground will be the fun. my 7700 or even the 6900 are for me anyway on 2s are only used in huge areas and they are a handfull to get them up to speed. getting that power down is near on imppossible (off road/grass) this will be impossible if its driven stupid. i just dont want a fire again. this will purely be for bragging rights and obscene videos. |
ORIGINAL: monsterbombs im surprised that vx esc hasnt let go yet. nice buggy? sorry if its not a buggy [:@] |
Hi there,
Glad you're willing to give 4S a try, I'm sure you will find it thrilling. I've had the chance to run really fast setups on both a 4wg buggy (kyosho lazer) and a stadium truck (losi xxxt) using the mamba max esc. The weather here is quite hot, and definitely affected the motor temps, so not all setups were trouble free. So far I've tried the following combos: 5700kv on 3s on the buggy - I'd say the fastest, takes off like a rocket due to 4wd. However, not a fun setup for the long term as it would eat trannys for breakfast, just too much torque for this buggy. Also had to keep an eye on gearing, proper gearing gave acceptable temps. while the truck has seen: 5700kv on 3s (a beast, but you have to keep an eye on temps) - I killed my motor after a while, can't gear too high) 4600 on 3S, very nice setup, runs quite fast and heat is not a big issue. 4600 on 4S - very close or just as fast as the buggy... the truck was a major beast with phenomenal acceleration. For this setup you should disable de mamba max internal BEC (and use external batteries for the receiver). Otherwise the system will be too hot and bad things will happen. On this setup I used a lower ride height (specially for the front) and mounted the receiver batteries at the front to minimize wheelies. (I used a wheelie bar too). The bad thing is you can´t overgear or risk killing the motor (killed it on the third run: switched gearing, got too excited and forgot to check temps). VXL on 4S - crazy fast setup, temps are not a problem, However it feels between the 4600/3s and the 5700/3s. I still have to try higher gearings... I'd say it's one of the "safer" setups to try 4S I do have a feeling that the VXL on 3S and a high gearing could be almost as fast as a VXL on 4S without the need and weight of the external battery pack... that's one setup I'd like to try. hope it helps EDIT: the truck with the 4600 on 4S had the fastest top speed, but I'd say the buggy on 5700/3S had the edge in acceleration. |
ORIGINAL: rufus2000 Hi there, Glad you're willing to give 4S a try, I'm sure you will find it thrilling. I've had the chance to run really fast setups on both a 4wg buggy (kyosho lazer) and a stadium truck (losi xxxt) using the mamba max esc. The weather here is quite hot, and definitely affected the motor temps, so not all setups were trouble free. So far I've tried the following combos: 5700kv on 3s on the buggy - I'd say the fastest, takes off like a rocket due to 4wd. However, not a fun setup for the long term as it would eat trannys for breakfast, just too much torque for this buggy. Also had to keep an eye on gearing, proper gearing gave acceptable temps. while the truck has seen: 5700kv on 3s (a beast, but you have to keep an eye on temps) - I killed my motor after a while, can't gear too high) 4600 on 3S, very nice setup, runs quite fast and heat is not a big issue. 4600 on 4S - very close or just as fast as the buggy... the truck was a major beast with phenomenal acceleration. For this setup you should disable de mamba max internal BEC (and use external batteries for the receiver). Otherwise the system will be too hot and bad things will happen. On this setup I used a lower ride height (specially for the front) and mounted the receiver batteries at the front to minimize wheelies. (I used a wheelie bar too). The bad thing is you can´t overgear or risk killing the motor (killed it on the third run: switched gearing, got too excited and forgot to check temps). VXL on 4S - crazy fast setup, temps are not a problem, However it feels between the 4600/3s and the 5700/3s. I still have to try higher gearings... I'd say it's one of the ''safer'' setups to try 4S I do have a feeling that the VXL on 3S and a high gearing could be almost as fast as a VXL on 4S without the need and weight of the external battery pack... that's one setup I'd like to try. hope it helps EDIT: the truck with the 4600 on 4S had the fastest top speed, but I'd say the buggy on 5700/3S had the edge in acceleration. alot of that is useful and well explained. i have never run a 4600 or 5700 motor. the 5700 on 3s might actually be what im after by the sound of it. well the battery is ordered, so i might go to work on the reciever battery. thanks again for the help mate. hopefully i can get it runnning with desired results. i will keep everyone posted. it would be good to hear from more people who have done this. even if it didnt work. |
just bought an BEC $12 shipped. hopefully arrives when the 4s does.
coool.. its a 5a too. found this heaps of info http://www.radiocontrolzone.com/show...=223182&page=5 |
I run an MMM with a 3300kv Medusa on 4s, have for a while now - no problems. Just bashing in short grass, no speed runs. Great power and no heat issues, you'll like the 4s setup lol....
4S is sick!
Forgot to mention most of my runs were on pavement. On 4S and offroad you'll really need great tires and a smooth throttle control, not really good for racing. Monsterbombs: What brand is the BEC you're getting? I might get one of those and get rid of the receiver pack. Also, since you'll use 4S have you decided which motor to get? If you get a buggy, bear in mind some do not have a lot of space for a 4S pack. On stadium trucks you can just add velcro straps, but on the buggy the chassis may interfere (this was the case with my kyosho lazer, the 3S pack would barely fit). |
ORIGINAL: rufus2000 4S is sick! Forgot to mention most of my runs were on pavement. On 4S and offroad you'll really need great tires and a smooth throttle control, not really good for racing. Monsterbombs: What brand is the BEC you're getting? I might get one of those and get rid of the receiver pack. Also, since you'll use 4S have you decided which motor to get? If you get a buggy, bear in mind some do not have a lot of space for a 4S pack. On stadium trucks you can just add velcro straps, but on the buggy the chassis may interfere (this was the case with my kyosho lazer, the 3S pack would barely fit). planes but meh. i got it on ebay. just type in bec or ubec. mine i think is 5-30v input 5/6v output. cheaper and easier than a reciever pack i reckon. the whole system is going into a 1/10 S/T and i will be using the velineon motor 3500. should haul. as for the battery fitting, it will be a bit tall but if i have to duct tape it in a sock (my personal fav) i will. lol. she'll go. |
4S should be just fine with the internal BEC. (Look up the specs on Castle's site if you want good references). The Velineon on 4S will be about the equivalent of a Mamba 5700 on 3S. Your packs shouldn't catch fire if you gear it right and/or you get batteries that are actually up to the job (AKA-25C or higher with relatively high amp-hours). Lipos have their limits, but I don't think most people understand the why's and how's very well. You'll get insane power on anything over 2S anyways, so going 4S would definately be worriesome on a 2WD. Have fun with it!
Actually, disabling the BEC is advisable because on 4S you have 14.8 Volts that the mamba esc needs to lower to 6V in order to feed the receiver and servo, so that's 8.8volts excess that it has to get rid off as heat going to the esc heatsink. On 3S that´s just 5.1volts excess so the ESC will be cooler. All that regardless of which motor you run. Well, that´s at least what should happen in theory, if anyone's tried this correct me if I'm wrong.
cheers. |
It all depends on the BEC. The Mamba Max is built to handle 4S, and the heatsink works quite well, so the extra juice lost wouldn't be a big deal if it actually isa linear BEC.
Now If it's a step BEC then you will have zero loss, as it only takes what it needs. I know for a fact that this is what they use in the new Mamba Max Pro because it's the same BEC in the new ICE speedies. As to the older ones, I'm not quite sure. Like I said though, your losses on a 5,000 pack are going to be very small (probablydown around 150mA or less) evenif it were linear. Big whoop-dee-doo. . . http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif You could realistically run the 4600 Mamba on 4S, so the VXL 3500 should be well within the limits. Heat may play a bigger role, but you can down-gear and still get insane speeds out of it. Just watch your temps and go slow with the gear changes. |
My new Mamba Max Pro is made for up to 6S, and does have a switching Bec that allows you to select your Bec Voltage. I bought it to use for Racing in a Mod Slash Class. I will only be running 2S with a Velinion. I bought it because of all the adjustability, and the fact that I can also just drop in a sensored motor if I want too.:D:D
I have run a vxl motor on 4s with a Mamba Max esc with a external bec and the vxl died within a day. Cant remember my gearing but the vxl got way too hot and died.
A VXL on 4s will turn 50,000+ rpms unloaded................too much IMO.
but what a blast it is digging double trenches in grass and
getting it up there. i was using a duratrax evader but i couldnt use the throttle because the ball diff would squele. now its in a bandit and i broke a hub carrier when testing. that was weeks ago,i need to get some cash and get it running again. soooooooooooo much power its silly. should have it running for the weekend hopefully. |
hey monsterbombs, you mentioned something about making obscene videos with the 4S pack...you got any yet? I would love to see them!
just picked up a 10mp camera so hopefully this weekend i will
have demon-dog like footage in descent quality ;) |
That thing has got to be completely insane on 4s[:@], cant wait to see the carnage in the vid!!:D
I ran my Blitz today on 4s, oh what fun. Handles, it pretty well IMO, just need a little throttle control. Squeeze don't yank lol, the Gladiators shred the grass better than a mower:D.
http://www.youtube.com/watch?v=phSLp3rFUIw
that took moons to upload. enjoy. (little yard run no room) |
