RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Electric Off-Road Trucks, Buggies, Truggies and more (http://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/)
-   -   Good servo for 1/8th scale buggy/truggy (http://www.rcuniverse.com/forum/rc-electric-off-road-trucks-buggies-truggies-more-147/9540263-good-servo-1-8th-scale-buggy-truggy.html)
ScottStaypuff 02-27-2010 01:05 PM
What is a good servo that won't break the bank to use for 1/8th scale. I would lke metal gear/ball bearing and maybe even digital.
If its good enough I have a Hitec HS-645mg I could take out of my Blitz 1/10th scale and use. Its got 133 oz.in at 6v. If I use this one I need to find a screw for a Hobbico metal gear servo http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNRP9 , any clue where to get one?
cummins driver 02-27-2010 01:58 PM
RE: Good servo for 1/8th scale buggy/truggy
A traxxas 2075 might work alright for you. It has 125 oz inches of torque and ball bearings. Its not metal geared, but you can get them for under $20 if you are wanting something cheap. Im not sure on the speed of it. If you are bashing it should be fine. For racing it may not be as good.
Eric
ScottStaypuff 02-27-2010 02:01 PM
Quote:
ORIGINAL: cummins driver
Eric
I might try to race it but somehow I don't think the Traxxas servo would be holding me back. :)
Anybody know what size screw my Hobbico servo takes???
cummins driver 02-27-2010 02:23 PM
I know what you mean:D Also forgot to mention the traxxas servo is digital and waterproof. I have one is my associated MGT and it works well enough in it. I think it would be better in a buggy with the smaller tires though
Eric
MCSRacing 02-27-2010 02:42 PM
hs645mg is a great servo ... i would swap it out
cummins driver 02-27-2010 03:12 PM
Yep, i had one of those in my sportwerks buggy and it worked great.
MCSRacing 02-27-2010 03:18 PM
usually i run the 645mg or digital 5645 in all my trucks and buggy's .. i have never blown a gear set or had one go bad .. i use a 7955 titanium geared servo in my truggy tho, bigger tires
ScottStaypuff 02-27-2010 04:29 PM
Quote:
ORIGINAL: MCSRacing
Good idea, the Hobbico servo is a good 1/10th scale servo: digital, ball bearing, metal gear, 83oz.in @ 6v. I might as well swap them out. In the meantime I figured out the Hobbico takes a 2.6mm x 8mm machine screw. I wonder if Lowe's would carry such a thing. Of course I have 6mm (a bit short) and 15mm here at the house. lol
ScottStaypuff 02-27-2010 04:51 PM
Ordered here: http://www.microfasteners.com/catalo...cts/METSCM.cfm
It just so happens Hi-tec HS-645MG takes the same size as the Hobbico.
