motor wires on ESC??
My Feedback: (20)
WI
Can cut the 3 motor wires on the ESC? (i have to solder them on the esc as well)
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWNX:IT
any help would be great, as you guys always help anyways. Thanks A Bunch!!! : )
IL
RE: motor wires on ESC??
dis particular esc dont look lyk it has motor wires, unles dos r solder cups, der only plugs lyk a mamba monster.
u meen cut da motor wires dat plug in2 da esc? shorten?
ON, CANADA
Get the shortest length of wire that will fit your build and cut them to this length. You may either solder the wires directly to the motor or use bullet plugs here. Then solder Bullet Plugs to plug in to the ESC.
The motor gets the male plugs if you don't solder the wire directly.
10AWG wire will do the trick and work well with 5.5mm or larger bullets.
Ryan
Ryan
Banned
MA
ORIGINAL: xerxes
ORIGINAL: dragnse7en
Please SPEAK PROPER ENGLISH - yo von der homeslice. That was immature from the get-go. You just got negative cool points in my book fer that yah? Derp A Herp Derp Derp - SPEAKENGLISH
ORIGINAL: xerxes
lolololol thats is funny
ORIGINAL: xerxes
