Another top speed build Help me pick vehicle
RE: Another top speed build Help me pick vehicle
ORIGINAL: MiamizFinest
^^^^ what just happen here?! LOL anyways proceed was a tremendous hobby grade car in its prime, it's just outdated and parts are near impossible to find, if I could find a roller I'd buy one for a shelve queen, I always wanted one but in its prime I was in middle school and could not afford one.
BTW I assumed you ment the electic TC3 chassis not the nitro, the nitro would be a decent choice nic case used it for the 134 mph pass at the first isc event. The electric tc3 is too flimsy IMO
Could I have that formula you are using to get that top speed? also How would I calculate top speed on a pan car? is the trans/drive ratio 1:1
Here. I made up a script and uploaded it to my website. This calculator will tell you everything you need to know by simply inputing some numbers
http://www.daytonashelby.com/gearing.php
And as for your 1:1 ratio, in the internal gear ratio, you would put 1.
Hope this helps you.
My Feedback: (27)
Here are a couple gear calculators you can use online or download.
http://www.rcracing.com/Gear_Ratio_Program_1100.cfm
http://www.gearchart.com/index.cfm?f...n=chart.create
http://www.rctek.com/miscellaneous/info_rcgears.html
http://www.scriptasylum.com/rc_speed/top_speed.html
ORIGINAL: azrhcp84
dang you getting me looking into pan cars... problem 1 TRACTION how how how would 2wd handle 4-5 hp lol would be so easy to build a custom ''pan car'' type vehicle
ive hit almost 80mph in my formula car, but it was smooth pebble free road with no wind.
so yeah, a pan car or formula car will be the least expensive way to go stupid fast, but you need a good place to run it first.
#32
ORIGINAL: proanti1
To be fair... parts are near impossible to find for any outdated 1/8th scale car.
#33
So the shark what you think pan car or tc series??? cost really does not matter to me... I can add weight to the pan car if I had to... but the less rotating parts seems like a better choice to me.... the main thing im worried about is being able to find a lot of options on wheel/tire combos
#34
well on paper a pan car with a 7700 3s could be VERY fast... if the motor has enough power to push past the drag at higher speeds... is there a formula weight/power/speed also?
