If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 13 of 13
  1. #1
    Join Date
    Mar 2012
    charlotte, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    First "REAL" on road car help.
    ok so i used to have a rustler and a micro T, dont have the rustler any more. But i really want something i can drift and race, but i want to do that with only changing tires.
    i have up to $160 with shipping and i have no rc suppies what-so-ever besides a few micro batteries. I Can buy used but i have no knoladge of whats good. Also it seems like all on-road cars are custom. So... With no building experience what so ever, could i buy an ARR and add parts to it because that would be cheaper? or should i stick to RTR. ANY help would be apreciated on this matter.
  2. #2
    Moderator Foxy's Avatar
    Join Date
    Mar 2005
    Kingston UK, but living in Athens, GREECE
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    In order to both drift and race successfully, you need to have a good understanding of the geometry of the car, ideally having built it yourself. They really are not challenging to build. Also, you have not allocated enough budget for even a kit that you could race, let alone an RTR. The RTRs you can get for that amount of money will perform poorly, but adequately, depending on your expectations. They will not be raceworthy, but may drift ok. Which brings me to the thing about changing only tires...that's not possible I'm afraid. A car setup for drifting, on grip tires on a track would be terrible. Similarly a car setup for track use would be extremely challenging to drift smoothly. It really can't be done, the two setups are completely opposite. You could do it by having another set of all 4 shock absorbers and 2 rear differentials, as well as the tires, but those are the minimum parts you would need to swap to change its role.
    If you really are interested in getting into the on-road hobby I strongly recommend saving a few more bucks and getting something good, ideally that you can build.
    The drift RTRs are a little more expensive, but at least they do what they are supposed to do well, drift. This is because you don't need high end electronics to drift. The normal grip cars are a little cheaper, but they have almost the same electronics, which are frankly inadequate for een just going fast outside the house. Their speed is not impressive. You need a brushless motor to go fast, and RTRs with brushless are somewhat more than you have to spend, especially if you need to buy a charger too.
    Try one of these to start with...
    http://www.amainhobbies.com/product_...z-Radio-System
    That is as cheap as I would ever go, and this car is not without its own minor issues. If you decided to wait and save a few more bucks, you could get this...
    The Sprint 2 is a much better car than the E10 and more importantly comes with a 2.4ghz radio, which means you will never lose control of the car to interference, and get more range than the AM radio included in the E10.
    In any case, the sprint 2 is the better platform to later put a cheap brushless set into.
    Down with the crew known to pump up the bass...
    We rock the joint at a cool, steady pace.
    Foxy
  3. #3
    Join Date
    Mar 2012
    charlotte, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    is there any good cars for either drift or touring thaat i can afford used or new? also how would you switch to brushless? do u have to do soldiering?
  4. #4
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    No, you don't usually need to do any soldering, particularly if you buy a brushless combo that's designed to be used together.
    There are no 'good' cars for what you want to spend. The E10 is absolutely the cheapest you should consider. 184 bucks for an RTR with 2.4ghz radio is a good deal.
    Foxy
  5. #5
    The Mad Modder's Avatar
    Join Date
    Oct 2006
    eastern, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    What about the tt01e? The e10 is kind of a problematic chassis due to it's weak transmission.
    God bless America
  6. #6
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    Can you get them rtr for 160? To be honest, I always forget Tamiya.
    Foxy
  7. #7
    phmaximus's Avatar
    Join Date
    Jun 2008
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    ORIGINAL: The Mad Modder
    is that from experience????
    I own a e10 and started the E10 thread, Every problem around the gearbox is from people not setting the gear mesh correctly, or from the mount comming loose.
    no kidding I know other people have had problems, but mine was a kit and was built with love, even shimed the diffs, Its been the most reliable car ive ever owned out of 17 car, still have 16 of them
    The e10 is perfect for people on a budget IMO
    LOSI: Micro SCT and Micro Truggy, Tamiya: TL01MT, Custom Clod 1/7 Hummer. Traxxas: Slash LCG 2wd. Axial: SCX10 Honcho. HL 1/24 Leopard Tank, QUAD's ZMR250 V1 FPV 1806 3s, ZMR250 V2 FPV 2204 4s, NQXF FPV 7x20brushed 1s
  8. #8
    phmaximus's Avatar
    Join Date
    Jun 2008
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    yes on paper the sprint 2 is a better car. But ive never seen a vid of a sprint out drift a e-10
    E10 will out drift a TT01, but a TT01 will out race the e10.... catch 22
  9. #9
    Join Date
    Oct 2006
    eastern, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    ORIGINAL: phmaximus
    I know it can be done, however you aren't exactly a beginner or on a $160 budget.
    God bless America
  10. #10
    narwalrus's Avatar
    Join Date
    Jul 2011
    San Clemente, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    ORIGINAL: Foxy
    My TT01ES RTR Evo X was $140 shipped. REMEMBER TAMIYA YO'
    Why didn't I get here earlier...
    Check ebay for tt01 xb/rtr
    SCX10 Hilux - Kyosho DRX - SCX10 6x6 - DF03Ra - M03 - Kyosho Turbo Ultima
  11. #11
    phmaximus's Avatar
    Join Date
    Jun 2008
    Adelaide, AUSTRALIA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    ORIGINAL: TheDriftingNarwhal
    ORIGINAL: Foxy
    I agree if the OP plans to race go the TT01, its a better racer than a e10, less understeer. But the TT01 wont really stand a chance against any true race car. I would get a sprint 2 over a TT01
  12. #12
    Join Date
    Mar 2012
    charlotte, VT
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    Too late, i just won a used HPI micro RS4. its 1/18 so its not too small and it came with tons of extras including 4 motors, 1 of them is brushless, but no battery and charger. Any tips or thoughts on my purchase, i spent $96 with shipping, and still need a battery and charger.
  13. #13
    Join Date
    Mar 2005
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: First
    It can only go on completely smooth surfaces which is kinda restrictive, but it's a decent model for what it does.
    Foxy
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
