Battery Issue?
Battery Issue?
I am new to RC and have a HPI Sprint 2 Drift. Completed all the setup and things worked well for a short period, suddenly the car studders on acceleration and in fact some times doesn't move at all. Is this just a sign of a depleted battery? With all the setup mode changing i am hoping nothing else got changed. A little worried about over charging the battery. The battery is a NI-MH.
Thanks for your help.
New2Drift
New2Drift
Hey guys, when buying lipo's its a common practice to change the connectors.
Some batteries don't come with any connectors.
to save your self some money it's really worth learning how to solder. Most hobby shops will do it for next to nothing or free if they are feeling nice lol... One of my local tracks/hobby shops charges $5
hummm that problem could be a few things... Most likely it's been switched to lipo mode
well new2drift and chil3ts44 we need more information and some diagnosing
so just to clarify, when everything is fully charges and switched on the car won't move and sometimes try's to move but shudders on acceleration
Is it the SP-15WP ESC?
it possibly might be on lipo mode....As that is the default mode for that ESC....
SC-15WP SET-UP
Battery Selection
One........Turn transmitter on
Two........Hold mode button down while switching
...........ESC on
Three......Release mode button RED LED will blink
...........once and beep
Four ......Press mode button hold it GREEN LED will
...........Blink once and beep
Five.......Press mode button repeatedly until correct
...........Mode is selected GREEN LED will blink the
...........correct number of times
....................One beep = NiMh
....................Two Beeps = LiPO
....................Three Beeps = LiFe
Six.................Hold mode button more than one second you will hear a short beep ...............and a long beep with the GREEN LED lit
....................ESC setting is now complete.
Seven...............Turn off ESC then transmitter
Eight...............To verify settings turn on radio, it will beep one two
....................or three times and RED LED will blink
Parameter Selection
Turn on transmitter
Put model on car stand, hold mode button down and switch on ESC
Release mode button.
RED LED blinks one time entering setting mode
Press mode button to enter next setting mode
Press mode button and hold it GREEN LED blinks one time
Pressing mode button will take you through each parameter
Pressing mode button for more then one second completes setting
Turn off ESC and transmitter
Parameter Modes
RED LED.........GREEN LED.............Action
one beep........one beep............. NiMh battery
................two beep..............LiPo battery*
................three beep............LiFo battery
two beep........one beep..............reverse off
................two beep..............reverse LOW
................three beep............reverse Medium*
................four beep.............reverse HIGH
three beep......one beep..............standard start
................two beep..............LOW start
................three beep............MEDIUM start
................four beep.............HIGH start*
four beep.......one beep..............brake OFF*
................two beep..............brake LOW
................three beep............brake MEDIUM
................four beep.............brake HIGH
* the default setting..............Hope this helps
Edited by skalar RC, 18 May 2013 - 08:58 PM.
Battery Selection
...........ESC on
Parameter Selection
Turn on transmitter
Parameter Modes
For some reason I can to find the manual for that ESC or any mention of it in the sprint 2 manual...
So I suggest try that quote above. But if anyone has a link to the official manual or instructions please post them here
