Stuck between the Tamiya TT-02 and HPI RS4 sport 3 flux
Hi guys, I'm stuck between buying the tamiya TT02 and the hpi rs4 sport 3 flux. I know out the box the HPI is an alround better car but cost a lot more. If I got the tt02 I was planning on doing a total makeover with a full YR racing hop us set, new gears and motor. In the long run I would do the same for the hpi but less would be needed. What is your opinion?
If you want speed go with the RS4 Sport 3 Flux. The Tamiya is a good car as well. You can pump $$ into either one to your liking.
Project: HPI Desert Land Shark - RS4 Sport 3 FLUX Build
tamiya tt02
I see where you having the problem. Well I got a TT02 with yeah racing parts and a exrun v10 G2 3.5T motor. It time to dial it in but it was well worth it. It's the fun of the build and plus it didn't break the bank. Oh I used a vaterra body pretty clean. Check mines out it give you an ideal.
