Official Tamiya TT-01 Thread
#6202
RE: Official Tamiya TT-01 Thread
I have the Porsche 911 VIP TT 01E and I want to know if anyone knows the difference between the locked differential and the one way differential. I bought an EZRun 5.5T brushless motor and I am trying to protect my gears.
#6203
good luck with that! the 5.5t is a monster, you're gonna strip gears most likely regardless. great combo though, speed and power for days!
#6204
Read more:http://www.rcuniverse.com/forum/m_41...#ixzz0u2Y2e9ho
Should I be worried about the spur gear or the differentials. I don't mind buying more spur gears because they are cheap.
#6205
hey guys, i've been racing my ride around with my friends and i got a few upgrade questions.
i've already purchased an aluminum driveshaft and bearings, what should i upgrade next for a smoother (non-racing) car?
and which longer-lasting battery & a better motor would u guys recommend?! i currently have a Duratrax Onyx 3000mAh 7.2V batt and a regular silver can motor...specifically which motor upgrade can the stock esc handle?! i dont want to go on a full upgrade as money is tight, so im probably just gonna upgrade the battery &/or the motor!
thanks everyone = )
thanks everyone = )
#6206
wilson, i would buy back up spurs and pinions, you will need them, it's inevitable.
frlud, keep the batery you have, with the stock ESC you cannot run lipo, so hold off till you can afford lipo, get a tamiya sport tuned RZ motor. hat was my first upgrade from the silver can. the stock ESC can handle down to a 19t (in my opinion and experience) but many would disagree and i think they're are warranted. $100 shipped for an ezrun system and you'll have more speed than you'll ever need.........
[youtube]http://www.youtube.com/watch?v=V5tczTMPv0g&feature=related[/youtube]
#6207
hey man thanks for the reply...
i was looking on ebay and all i found was the sport tuned RS motor & the super stock RZ motors from Tamiya...which one specifically are u talking about?! and how many T does the stock silver can have? i feel llike such a nooob for asking so many questions, but i think this forum is the perfect place to ask! = )
thanks a lot for all yoru help!!
#6208
super stock RZ is the one i was refering to, sorry for the confusion, in regards to the silver can question,the tamiya silver can is 27t
#6211
hehe i did watch that video man!
but im not sure, i might have shaky hands and DUNK the whole thing into the water = P
i'll see when i get the motor. how significant is this method to the speed of the car?! and i can i test out the motor first and then do the method and then see the improvement?!
#6215
What is the best pinion/spur combination for my TT 01E? I ordered the EZRun 5.5t brushless and I want to change the pinion/spur combination since I will be removing the motor anyway.
#6217
hey guys, today i finally went to my local 7-11 to pick up my aluminum drive shaft...and after a frustrating half hour of trying to fit it all in, i went for a test run! = P
however, the aluminum shaft gives a sort of rattling noise. is this normal?? i am positive that i have installed everything correctly, and i have re-greased all the original parts + the shaft itself.!!!
#6219
what do u mean "spacer"??
sorry for the nooobnesss, but i followed exactly as the diagram. i have the tamiya aluminum propeller join & shaft set (54026) and on the instructions it says just follow the instructions as is.
so i stick the rear propeller join through a plastic bearing & a spur gear stopper (in the right direction), slip in the small shaft and stick all of that through the spur gear... i then slip in the front propeller joint and snap in the propellor shaft itself...with everything screwed in tight the propellor shaft can shift front & back about..2mm?!
#6220
I think I am referring to the spur gear stopper, making sure it's in the right direction and all the parts are in the correct place. If it's all correct then I would replace the plastic bushings with metal bearings and their a very good investment for durability and speed.
#6221
Open up your diff casing and check inside if the diff gears are all properly aligned. When you take a prop shaf out, sometimes the diff gears can get a bit out of place...
Happened to me once...
#6222
picked up the race version of the TT01. This thing is pretty nice. comes with everything you would want except for the aluminum motor mount.
I modified the stock steering servo linkage to a turnbuckle style like the original TT-01R
#6223
NV
ORIGINAL: GHWilson87
I hope I explained that correctly. I know what I wanted to say, but sometimes my fingers don't cooperate, so if anyone else want to jump in, feel free.
#6224
i got a regular tt01 and just wondering whats the cheapest way to give it a bit more speed. I know i can go brushless but with the ESC and Motor im looking at $100 bucks. Just want more speed for parking lot bashing
