RC Electric On-Road vehicles, race cars and more Discuss electric RC on-road vehicles here. Also discuss brushless motors, speed controllers, brushed motors, etc
OFFICIAL HPI Sprint 2 Thread (Sport and Flux)
Old 10-29-2011, 08:45 PM
  #1251
t9dragon
Default RE: OFFICIAL HPI Sprint 2 Thread (Sport and Flux)
I should have my second hand Sprint 2 Flux on Monday.. I can't wait to do some on road racing again...
Old 11-03-2011, 06:27 AM
  #1252
drc35ca
I made a tensioner for the rear belt ans seems to help alot compared to before it was jumping constantly even after adjusting. It does not jump anymore and with the more powerfull 5900kv 4 pole motor the belt is holding up well after 20 runs using a 5000mah belt and 35-40 mins of hard running on carpet!
I used a front tensioner turned upsidedown,replaced bushings with bearings and put a flush mounted screw to hold the bearing mount into place because of motor plate clearance!
Too bad this was not made of aluminum with a slot on the holder to move the bearing up and down as needed??
Anyone else try this??
I wonder if aluminum 15t pulleys would help slow down belt wear as plastic seems to round off fast?
Old 11-03-2011, 07:01 AM
  #1253
ThunderbirdJunkie
ThunderbirdJunkie's Avatar
http://www.exotekracing.com/sprint-spx-pro-chassis-set/
This is relevant to ThunderbirdJunkie's interests...
Old 11-03-2011, 07:16 AM
  #1254
paba60
My Feedback: (96)
ORIGINAL: ThunderbirdJunkie
Looks yummy...love the fact that the chassis is open in the front and rear...
Old 11-03-2011, 07:31 AM
  #1255
t9dragon
Well, I got my first Sprint 2 this week in a trade and I should have another early next week.. I was able to trade both mine and my son's Mini Revos' for each of the Sprint's.
One comes with the Flux brushless setup and the other one comes with a Novak brushless setup.
Here are pics of the Flux one.
And here are a couple of the back and fins...
Old 11-03-2011, 08:22 AM
  #1256
ThunderbirdJunkie
That's the first good looking RC '57 Chevy body ThunderbirdJunkie has seen. Is that a Pegasus body?
Old 11-03-2011, 10:11 AM
  #1257
t9dragon
I am not sure, it came with the car.
Do you guys know which wheels I need to get to run the 200mm bodies on my Sprint?
Old 11-03-2011, 03:02 PM
  #1258
t9dragon
It is made by Parma.
Old 11-03-2011, 05:51 PM
  #1259
SerpentCT4S
I like that Exotek chassis set. One of my Sprint's has the HPI carbon fiber. I am going to get the Exotek for my other Sprint.
Old 11-06-2011, 09:18 PM
  #1260
arcboyz
My Feedback: (7)
Heres a video of my sprint2 flux on 3s lipo havent done any mods other than LED light kit with turn signals ect
http://www.youtube.com/watch?v=0MZqH3o4GVQ
Old 11-08-2011, 07:24 PM
  #1261
32_d3gr33s
32_d3gr33s's Avatar
ORIGINAL: arcboyz
3S? I thought they are only capable of running 2s?
Old 11-08-2011, 08:06 PM
  #1262
ThunderbirdJunkie
ORIGINAL: t9dragon
WOW really? ThunderbirdJunkie has seen the Parma ones and he thought they were horrid. Maybe this is the first properly painted one.
Old 11-08-2011, 08:53 PM
  #1263
t9dragon
ORIGINAL: t9dragon
I have the Parma one on order at the LHS and then I will know for sure if they are the same. It is funny out of all the rc's I have had the wife loves the Chevy Bel Air body.
Old 11-09-2011, 09:24 PM
  #1264
ibeast
i bought a sprint 2 drift from ebay cam with the castle 4600sidewinder setup one way diff in the front and ball diff in the rear and a bunch a hop up parts it also came with the gearing 28t pinion to a 87 spur what would be a better ratio and also i have alot of slack on my belt and i just put new belts on im a newb to the electrical drifting and was wondering what shock spring shold i get
Old 11-09-2011, 11:13 PM
  #1265
arcboyz
My Feedback: (7)
ORIGINAL: 32_d3gr33s
ORIGINAL: arcboyz
yes that vid is with everything stock on 3s lipo the only thing added is the LED kit
Old 11-10-2011, 08:08 AM
  #1266
32_d3gr33s
32_d3gr33s's Avatar
i was under the impression that it could only handle 2s lipo's... what lipo do you have? my 2s barely fits, and my 3s is a lot larger. I would love to rip on this with a 3s!!
Old 11-10-2011, 04:27 PM
  #1267
Uncle Vinnie
Look on the previous page and you'll see how you can fit 3s lipo.
It's much better than having the stock setup
Old 11-11-2011, 10:03 PM
  #1268
arcboyz
My Feedback: (7)
its a small venom 3s from my savage xs ill post some pics in the morning
Old 11-13-2011, 06:36 AM
  #1269
drc35ca
Try making a rear tensioner like I did? Very easy just order another front tensioner and use 2 bearings on the pulley instead of bushing
I got about 35 very hard runs (of about 45 mins each on a 5000mah) out of the rear belt before I had a runaway and hit the wall pinning full throttle and tearing the teeth off the belt and upper pulley . My 2.4 hpi radio came unbound or something,still trying to figure it out?
The belt did stretch somewhat but remained in good condition until the WOT hitting the wall.
Old 11-13-2011, 10:33 AM
  #1270
Uncle Vinnie
Quick update on one of my posts on page 50 regarding the motor being not centered on the chassis.
Last night I met someone that actually was following my post and trying the mods, I mentioned to him not to do it, the Middle Lay shaft kept braking.
Motor - Not an easy fix, but why hasn't HPI seen this and corrected it. If you take a look at the stock position of the Motor, looking at it from the front to the car the motor sits a few mm to the right.
Get three 4mm nuts, we all have them in our tool box and install them on the motor plate (see photo below), where you're going to have problems in with the Middle Lay Shaft you need to drill a hole to compensate for the 4mm shift (I ruined the original one, had to get another, got it the 2nd time). After this is done your motor will sit right in the middle of the chassis and not to the right.
This mod on paper was a great idea, unfortunately in the real world did not work out that well, due to having to drill another hole through the Middle Lay Shaft it actually weakness the shaft on the area of the original and the extra hole made, I have broken to shafts on that spot, went back to the stock setting,
Here is the pic I'm referring to.
Old 11-13-2011, 10:50 AM
  #1271
t9dragon
Here is a quick picture of the 2 HPI Sprints that I traded for 2 weeks ago..
Old 11-19-2011, 08:49 PM
  #1272
specialformula
so im looking at this duratrax element brushelss system for my sprint 2 .. its just a basher.. mostly drift.. any one have any expreience or know id this would be a good option for this car??
here are the specs..
http://www.duratrax.com/motors/dtxc3122.html
local shop will sell me one for 100 bucks..
Old 11-20-2011, 09:54 AM
  #1273
Uncle Vinnie
That looks like the castle creations Neu-Castle 1406 series brushless motor with the Sidewinder ESC can't tell if its the original or V2
Noting wrong with that system, I have the same one with 5700 motor, more than enough power, what I really don't know is how much power difference is there from a 3900 to 5700 motor.
Old 11-20-2011, 11:38 AM
  #1274
specialformula
ya that seems to be my main concern . power... the guy at the hobby shop reccomented it.. saying that all the ppl with big motors are tuening down to smaller motors so they can actually dive the car.. or should i get just somthing 5700 kv..
seccond question is about the heat .. im new to RC , wondering what gearing i need or if this would be a proper match for the car .
im just to new yett to have enough of my own judgement.. in time in time.. =)
thx
Old 11-20-2011, 02:39 PM
  #1275
Uncle Vinnie
The guy on at the hobby shop is right, I have mine tuned down to 5000kv, and its still plenty of power.
I've never had any problem with heat, the hottest mine has ever gotten was 167F, that's racing with various types of gearing...
The heat issue is something only the driver/owner of the car has to figure out based on what you will actually be doing.
