what bodies fit on the HPI E10
im buying an HPI E10 and i wanted to order a body off of there website www.rcplanet.com and im wondering if the length of a body matters like the HPIs length is 375mm but the bodies length is 450mm or 475mm
RE: what bodies fit on the HPI E10
there are three kinds of body for 1:10scale on-road cars 180mm, 190mm, 200mm that is the width, most 1:10 bodies are compatible.
ORIGINAL: SIRCC
Actually the 190mm is the body used on electric 1/10 TC's, the 200mm is used on the nitro 1/10 TC's.
Any body that is 190mm will fit the E-10. HPI, Proline and Parma all make 190mm bodies.
hers another question is it exspensive to replace brushes on 15 turn motors is it hard to do why do you have to do it? please help im a little clueless wether or not brushless motors are worth it?
It is not expensive to replace brushes.. but can get pricey if you have to do it frequently. The reason to replace them is as they wear it reduces their efficiency. With the price of an entry level brushless system running from 80 to 120 bucks it seems to be more economical to persue that route.
are they faster does 120 bucks get you everything you need to install it is it hard to install? sorry i have to many questions but i want to know more becuase i want to be sure what to upgrade with pleaase answer if you know?
AB, CANADA
either the 4600 or 5700 will work for drifting. I personally like using the 200mm bodies as I put the fake disk brakes and they put an offset of about 5mm on each side which means the 200mm works great.
http://www.rcmart.com/catalog/rc-tir...l?cPath=35_292
