RECIEVER HOOK UP QUESTION
MS
Hello Everyone
this is my first full blown kit so dont burn me to much
I have gotten an tt01 kit and a Spektrum dx 2. o radio and SR3000 DSM 3-Channel Receiver
my question is im confuses on how to connect my tamiya TEU-101BK esc to the reciever
where do i plug the leads to the reciever, i dont want fry the reciever nor the esc
any help would be greatly appericated
1 Post
RE: RECIEVER HOOK UP QUESTION
I think you will need a BEC as the 101bk esc does not have one you will fry your servo and RX. That being said go on the tamiya website and they have the instructions you need.
The SR3000 is rated up to 9.6 volts, but your servos probably aren't so I would use a BEC to step down the voltage to 6V as redfisher1974 mentioned
MS
Thanks guys
Bok
i have the servo's supplied with the reciver
so will i still need the bec so all will be good to go when hooked up correctly
thanks again guys
Bok
thanks again guys
Yep... tamiya receivers are retarded. This is how I plugged it into my sr300. Red plug in aux slot (black wire outside, red wire middle), then the other plug went in the throttle slot. You might have to shave some of the red plug down so it will fit. The esc has a built in BEC.
1 Post
Dont you mean tamiya ESC's? and they dont have a built in BEC, You get the full voltage from the battery. That being said most cheap AM RX's have a bec but specky's do not.
Redfisher is right, the TEU101BK does not have a built-in BEC. I measured the voltage coming off the red plug on my TEU, an it was the same as the battery voltage of my freshly charged pack, around 8.4 volts. Not good for your servo!
MS
so will this bec work i found on tower hobbies
http://www3.towerhobbies.com/cgi-bin...?&I=LXYAN4&P=7
thanks for all the help guys really really needed it
Nope that will not work, you need something like this: http://www3.towerhobbies.com/cgi-bin...&I=LXSWL3&P=ML
Or this
http://cgi.ebay.com/Hobbywing-3A-UBE...item3efdab7e1f
I myself have the Hobbywing UBEC, works great
Or this
