Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Electric On-Road vehicles, race cars and more
Reload this Page >
Is Corrosion X Okay to Use on Brushed Motors After Wet Runs?
RC Electric On-Road vehicles, race cars and more Discuss electric RC on-road vehicles here. Also discuss brushless motors, speed controllers, brushed motors, etc
Old 07-03-2010, 11:11 PM
alexchen86
alexchen86's Avatar
Default Is Corrosion X Okay to Use on Brushed Motors After Wet Runs?
I always keep my brushed motors lubed and free. Usually I use CorrosionX in aerosol form to spray into the bushings a couple of squirts and lube the bearings and roll it freely a few times after heavy mud/water runs.
However everytime I go for another run I can see smoke and occasionally a flame shoots out the motor lol. I use CorrosionX on motors and I pack as much lithium grease as possible into the diffs and axle housings to block out mud/water when I go mudding. But the smoke and the flame worries me....
Old 07-04-2010, 08:50 AM
proanti1
proanti1's Avatar
Default RE: Is Corrosion X Okay to Use on Brushed Motors After Wet Runs?
I wouldn't use anything that coats the comm... All you need to do is oil the bearings. Slight oxidation on the brass comm paddles will not effect conductivity.
Old 07-04-2010, 12:19 PM
Ttam Says Blarg
Ttam Says Blarg's Avatar
I thought people used that stuff to water proof there electronics? Its not uncommon to see sparks but flame.... Cant be good.
Old 07-04-2010, 01:38 PM
alexchen86
alexchen86's Avatar
Well the reason I use Corrosion X spray onto the brushes and comm is to try to prevent muddy water from building up in there after deep mudding or dirty water runs that completely submerges the motor.
I stopped spraying the motor's internals now after reading some more...it seems Corrosion X lasts for a long time after application. I probably sprayed way too much in there and it just kept building up.
Something in it is probably a bit flammable and a spark from the motor probably set off a little fireball lol.
Old 07-04-2010, 04:58 PM
proanti1
proanti1's Avatar
Well its basically wax... which is flammable.
