RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   RC Electric On-Road vehicles, race cars and more (http://www.rcuniverse.com/forum/rc-electric-road-vehicles-race-cars-more-475/)
-   -   castle sidewinder sv2 wont calibrate (http://www.rcuniverse.com/forum/rc-electric-road-vehicles-race-cars-more-475/10626137-castle-sidewinder-sv2-wont-calibrate.html)
tamiyaman55331 07-17-2011 07:36 PM
i just baught a castle creations sidewinder sv2 motor and esc but they wont calibrate. all the leds seem right but i dont get power to the motor, just the servo. please help.
gokemidoro 07-17-2011 08:01 PM
RE: castle sidewinder sv2 wont calibrate
Did you get the Castle link or QFPC (quick field programming card)? If not, you are missing out on 60% of it's programming capability.
One of my Castle ESC's won't calibrate, either, using those darn beeps. Using the Castle link, calibration is done automatically. You can program everything you need with it. That ESCworks now, as it should, andall of my Castle systems (8) do as they should.
Irecommend the QFPC, as you can use it as a link, with a USB cable, and it will work with any Castle ESC.
xerxes 07-17-2011 08:05 PM
flip ur throttl chanel reversing frum N to R.
den re calibrate
dragnse7en 07-17-2011 08:29 PM
Yes - if you have a Futaba radio, you'll most likely need to put the TH channel in REV.
1. Turn on controller. Pull throttle trigger to full throttle.
2. Turn on car. Keep your finger on the trigger with full throttle. You should hear the arming beep, a pause, and then a bunch of chimes. It's ready to calibrate. The little tune it played is saying it understands you want to calibrate and it sees full throttle.
3. Push throttle trigger to full brake. Wait for esc to chime again to let you know that it sees full brake.
4. Bring throttle trigger to neutral, or let go of the trigger. The esc will chime to say it sees neutral, followed by a pause, and then it will chime sorta the same tune to say that it's happily calibrated.
octanehuffer 07-19-2011 04:36 PM
I had this issue last month. Spoke with a tech at Castle. Turned out that it was my older Magnum Jr wouldt give the proper signal for throttle. E ven though the transmitter works perfectly, it was a programming issue. Castle even sent me link for free.
SyCo_VeNoM 07-19-2011 04:55 PM
had same issue with a FlySky GT3 (the original the B supposedly works, GT2 works) with a CC ESC
They have issues with some radios
hindupimp2384 07-20-2011 10:49 AM
Dudu come on Call CASTLE they will know what your issue is.
