Why Don't Photo Field airports show up in G3.50.65?
Ihave G3.50.65 andI've downloaded and imported many planes, but when Idownload Photo Fieldairports and import them they say it was imported successfully, but Ican't find them anywhere.Ican get "Other Airports" to import, but anything that says "Photo Field" or a file that ends with "PI" will not show up in my custom folder.What am Idoing wrong? How do Iget the downloaded/imported "Photo Fields"airports to show up? And I'm downloading all the airports that say they are for G3.50.65 or older. Ireally wantto get the UtahModelPort rf._PI
and again that's a PIfile. Help!Thanks!
PROBLEM FIXED!!! Read below....
RE: Why Don't Photo Field airports show up in G3.50.65?
No Ihaven't They were closed when I posted this. I am able to download someairports and import them,but if it's a "Photo Field" it won't work. I'll call them and see what they say.
ORIGINAL: zac137
Try running it as administrator. I had the same problem and that sovled it.
Zach
Zach
How do Iput it in admin mode?
NE
Just right click on the icon(when first opening the program) and go down to "run as administrator" and that should do it.
Zach
ORIGINAL: zac137
Just right click on the icon(when first opening the program)and go down to "run as administrator" and that should do it.
Zach
Zach
Okay., I got the photo fields to work, But you need to unzip the folder, import from the Raw Panoramic Image, and go into the editor. I really don't know how I did it, but I got 2 different airports to work. Now I just don't know how to save them in the select airport menu.
NE
Ok, I think I might not have explained what to do very well.
On your main desktop screen right click on the G3.5 icon, and a drop down menu will show, left click on the "run as administrator" and then you will get a dark screen asking your permission to open the program. Click "allow" and then you should be able to open the program as normal. The airports should all be in your custom folder.
If that is what you did let me know and I will do some research and try to recreate the problem on my computer and see if i can give you better advice.
Zach
ORIGINAL: zac137
Zach
Zach
Rick
