Cable or transmitter problem?
I recently bought two of these cables:cgi.ebay.com/RC-USB-Flight-Simulator-FMS-Cable-Futaba-JR-ESKY-/180627319164
Unfortunately I cannot use my aileron channel. I don't know what is going wrong with it. The problem is only the aileron, other channels are ok... I have tested the transmitter in a real airmodel and it is working properly.
Any idea of what I could do to solve this issue?
RE: Cable or transmitter problem?
Those are most likely the economy cables from a certain country in
the asiatic reason.
I had a similar problem.
Delicately you have to cleaan the pins with some fine sandpaper and try not to bend them.
It's what I did on mine and so far they have been working ok.
The pins are not as good as the ones on name brand JR or Futaba cables unfortunately.
the asiatic reason.
