Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
Reload this Page >
Just Upgraded to RF7 With a Question?
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 03-03-2014, 04:08 PM
hookedonrc
hookedonrc's Avatar
Default Just Upgraded to RF7 With a Question?
Since this was just an upgrade, I was under the impression that my planes from 6.5 would be usable in 7. However I can't seem to find them. Is there something I must do to import them? Or am I under the misconception that features like planes and flying sites in earlier versions would be available in subsequent releases?
Old 03-04-2014, 05:00 PM
hookedonrc
hookedonrc's Avatar
Got the answer....just reinstall the expansion pack in the correct directory and you are set.
Old 03-10-2014, 11:23 AM
opjose
opjose's Avatar
Note that a few planes previously in the expansion packs have been added to the default aircraft and made available only after you complete the challenges.
e.g. the Wolf Spyder on Expansion Pack 2 ( or is it 3 ) will not appear, even if you have the expansion pack installed until you complete the corresponding challenge.
Old 03-10-2014, 11:27 AM
hookedonrc
hookedonrc's Avatar
Thanks for the info, I didn't know that.
Old 03-11-2014, 09:57 AM
opjose
opjose's Avatar
Of course the end users have already discovered that if you Export a AV file from Realflight 6.x of the missing aircraft, then import it into Realflight 7.x, then you can forgo the challenges to see the plane.
Tricky rabbit!
Old 03-11-2014, 10:13 AM
hookedonrc
hookedonrc's Avatar
Also good to know...I will have to make note of which planes are missing and add them.
