Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
Reload this Page >
RealFlight 7.5 RealWinners Sweepstakes on Facebook!
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Reply
Old 10-19-2014, 10:29 AM
aejinks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thumbs up RealFlight 7.5 RealWinners Sweepstakes on Facebook!
Hey everyone!
There is a RealFlight Sweepstakes on there Facebook where you can win the new 7.5, $50 merchandise certificates or mega update packs!
Here is the link: http://a.pgtb.me/d50DGF
aejinks is offline
Old 10-19-2014, 01:08 PM
steph69
steph69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
went on their facebook page could not find there form anywhere, I just bought realflight 7 and know this is out bit disappointed.
steph69 is offline
Old 10-20-2014, 05:09 AM
aejinks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you go to their FB site,(https://www.facebook.com/realflight) it should have a tab on top under their cover photo that says "RealFlight RealWinners" Click on that and the entry form should be there. I think it's USA only though. You'll be able to download the new 7.5 for free since you already own RF 7.
aejinks is offline
Old 10-28-2014, 11:04 AM
N410DC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
For those of us who already have version 7, when will 7.5 be available for download?
N410DC is offline
Old 10-29-2014, 11:07 AM
aejinks
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
End of October, so really soon. It will be a free download if you already own RF 7.
aejinks is offline
Old 11-02-2014, 10:11 PM
N410DC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Answered my own question; 7.5 was automatically downloaded when I booted up 7.0 today.
N410DC is offline
Old 11-02-2014, 10:14 PM
N410DC
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Here are the 7.5 Release Notes:
* --- This version is NOT compatible with XP. ---
* [See the announcement here for a more detailed look at the new 7.5 features: http://www.knifeedge.com/forums/showthread.php?t=31206]
* MAJOR FEATURES:
* Wireless SLT Interface
* Multirotor Support
* Improved Aircraft Editor
* Scavenger Hunt Challenge
* Challenge Ghost Runs
* NEW AIRCRAFT
* Great Planes Kunai
* Top Flite Zero
* Tricopter 900 (standard version plus "Manual Modes" variant that includes Acro flight mode)
* Explorer 580
* H4 Quadcopter 520
* X8 Quadcopter 1260
* Dead Cat Quadcopter 580 (Quadcopter Trials challenge reward)
* Hexacopter 780 (standard version plus "GPS Modes" variant that includes Return to Launch flight mode)
* Octocopter 1000
* Eldritch Copter (Scavenger Hunt challenge reward)
* Quadcopter X (previously an unlockable reward, now freely available)
* NEW AIRPORT:
* Japanese Temple Airport
* ________________________
* FIXES/IMPROVEMENTS:
* Fixed a crash that occurred if the InterLink Elite's "Select" button was held down on startup
* Fixed a crash that occurred if an invalid aircraft variant (one that is based on a nonexistent vehicle) was selected in the aircraft quick select dialog at the time it was closed
* Added a series of motors that are suited to multirotor use. They are named "KEMR____"
* Aircraft Editor: The Electronic Flybar component's Elevator and Aileron gyros have more suitable default values (they are different than the Yaw gyro)
* Aircraft Editor: The Edit menu's Rescale Physics to... option affects Camera component: Location in Parent & Shock Mount Range, Linear Actuator: Endpoint Location, and projectile component (various): Location in Parent
* Aircraft Editor: The Wing component's Wing Length, Chord at Root, and Chord at Tip properties have better default values
* Aircraft Editor: Symmetrical components use Left/Right terminology for greater clarity
* Aircraft Editor: Copied components are not added unless/until they are pasted
* Aircraft Editor: The "Fuel Level" setting is not affected when property values change
* Aircraft Editor: The duplicate "2 pct Rounded Flate Plate" airfoil is removed. RealFlight will silently use the identical "2 Percent Flate Plate" airfoil instead
* Aircraft Editor: For electronics components with subcomponents (such as the Electronic Flybar and new Multirotor Flight Controller), the parent component does not appear in input selection dropdown controls
* Aircraft Editor: For electronics components with subcomponents, the parent component name is prepended to the subcomponent name in input selection dropdown controls (ex: "Electronic Flybar: Yaw")
* Aircraft Editor: Deleting an engine component stops its RPM sounds from playing
* Aircraft Editor: Min/max/default property value label text is shortened
* The on/off setting for software radio dual rates & expo is applied correctly after changing controllers and radio profiles
* When software radio dual rates & expo are disabled, software radio trim is also disabled
* Switching to a new airport from one with a different terrain density does not affect collisions for snap-to-ground objects
* Information in the MFC Aircraft Selection dialog's Specifications tab is reordered. Also, Wing Area and Wing Loading are not displayed for vehicles with no wings
* Using the InterLink's Cancel button to close the Challenge Select dialog does not leave the UI disabled
* Edit Radio Profile dialog: Dual rates/expo checkbox is enabled and disabled correctly
* Challenges: The level finished dialog displays previous best times in minutes and seconds
* Challenges: Previous zoom settings are restored after exiting a challenge
* Chaff from vehicle breakapart is cleaned up when a different vehicle is loaded
* The edit aircraft menu item is disabled in MultiMode
* Added a Tactic TTX610 Quick Start document, available via Help menu
* Updated the Italian and French translations
* AIRCRAFT CHANGES:
* AH-64 Apache: Fixed some minor setup issues with the tail fins
* Mitsubishi A6M Zero: Fixed smoke size and origination point
* Simple Flier: Completely updated the art
* Thunder Tiger E700 (stock): Added missing quick select preview image
* AIRPORT CHANGES:
* Shipwreck HD: Added missing preview for selection dialogs
N410DC is offline
