RealFlight 7.5 RealWinners Sweepstakes on Facebook!
Hey everyone!
There is a RealFlight Sweepstakes on there Facebook where you can win the new 7.5, $50 merchandise certificates or mega update packs!
Here is the link: http://a.pgtb.me/d50DGF
went on their facebook page could not find there form anywhere, I just bought realflight 7 and know this is out bit disappointed.
If you go to their FB site,(https://www.facebook.com/realflight) it should have a tab on top under their cover photo that says "RealFlight RealWinners" Click on that and the entry form should be there. I think it's USA only though. You'll be able to download the new 7.5 for free since you already own RF 7.
Here are the 7.5 Release Notes:
* --- This version is NOT compatible with XP. ---
* [See the announcement here for a more detailed look at the new 7.5 features: http://www.knifeedge.com/forums/showthread.php?t=31206]
* MAJOR FEATURES:
* Wireless SLT Interface
* Multirotor Support
* Improved Aircraft Editor
* Scavenger Hunt Challenge
* Challenge Ghost Runs
* NEW AIRCRAFT
* Great Planes Kunai
* Top Flite Zero
* Tricopter 900 (standard version plus "Manual Modes" variant that includes Acro flight mode)
* Explorer 580
* H4 Quadcopter 520
* X8 Quadcopter 1260
* Dead Cat Quadcopter 580 (Quadcopter Trials challenge reward)
* Hexacopter 780 (standard version plus "GPS Modes" variant that includes Return to Launch flight mode)
* Octocopter 1000
* Eldritch Copter (Scavenger Hunt challenge reward)
* Quadcopter X (previously an unlockable reward, now freely available)
* NEW AIRPORT:
* Japanese Temple Airport
* ________________________
* FIXES/IMPROVEMENTS:
* Fixed a crash that occurred if the InterLink Elite's "Select" button was held down on startup
* Fixed a crash that occurred if an invalid aircraft variant (one that is based on a nonexistent vehicle) was selected in the aircraft quick select dialog at the time it was closed
* Added a series of motors that are suited to multirotor use. They are named "KEMR____"
* Aircraft Editor: The Electronic Flybar component's Elevator and Aileron gyros have more suitable default values (they are different than the Yaw gyro)
* Aircraft Editor: The Edit menu's Rescale Physics to... option affects Camera component: Location in Parent & Shock Mount Range, Linear Actuator: Endpoint Location, and projectile component (various): Location in Parent
* Aircraft Editor: The Wing component's Wing Length, Chord at Root, and Chord at Tip properties have better default values
* Aircraft Editor: Symmetrical components use Left/Right terminology for greater clarity
* Aircraft Editor: Copied components are not added unless/until they are pasted
* Aircraft Editor: The "Fuel Level" setting is not affected when property values change
* Aircraft Editor: The duplicate "2 pct Rounded Flate Plate" airfoil is removed. RealFlight will silently use the identical "2 Percent Flate Plate" airfoil instead
* Aircraft Editor: For electronics components with subcomponents (such as the Electronic Flybar and new Multirotor Flight Controller), the parent component does not appear in input selection dropdown controls
* Aircraft Editor: For electronics components with subcomponents, the parent component name is prepended to the subcomponent name in input selection dropdown controls (ex: "Electronic Flybar: Yaw")
* Aircraft Editor: Deleting an engine component stops its RPM sounds from playing
* Aircraft Editor: Min/max/default property value label text is shortened
* The on/off setting for software radio dual rates & expo is applied correctly after changing controllers and radio profiles
* When software radio dual rates & expo are disabled, software radio trim is also disabled
* Switching to a new airport from one with a different terrain density does not affect collisions for snap-to-ground objects
* Information in the MFC Aircraft Selection dialog's Specifications tab is reordered. Also, Wing Area and Wing Loading are not displayed for vehicles with no wings
* Using the InterLink's Cancel button to close the Challenge Select dialog does not leave the UI disabled
* Edit Radio Profile dialog: Dual rates/expo checkbox is enabled and disabled correctly
* Challenges: The level finished dialog displays previous best times in minutes and seconds
* Challenges: Previous zoom settings are restored after exiting a challenge
* Chaff from vehicle breakapart is cleaned up when a different vehicle is loaded
* The edit aircraft menu item is disabled in MultiMode
* Added a Tactic TTX610 Quick Start document, available via Help menu
* Updated the Italian and French translations
* AIRCRAFT CHANGES:
* AH-64 Apache: Fixed some minor setup issues with the tail fins
* Mitsubishi A6M Zero: Fixed smoke size and origination point
* Simple Flier: Completely updated the art
* Thunder Tiger E700 (stock): Added missing quick select preview image
* AIRPORT CHANGES:
* Shipwreck HD: Added missing preview for selection dialogs
* MAJOR FEATURES:
* NEW AIRCRAFT
* Top Flite Zero
* Explorer 580
* H4 Quadcopter 520
* Octocopter 1000
* NEW AIRPORT:
* AIRCRAFT CHANGES:
* AIRPORT CHANGES:
