Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
Reload this Page >
Model's exhaust smoke on Real Flight 7.5 simulator
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Reply
Old 01-19-2016, 06:03 PM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Model's exhaust smoke on Real Flight 7.5 simulator
On my old Real Flight G2 simulator I was able to turn off the exhaust smoke from the model that I was flying but on my new RF 7.5 I can't find what turns it off. Hopefully someone can assist me with this. Thanks.
karolh is offline
Old 01-20-2016, 10:46 AM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
There is a problem with RF and smoke. There is smoke, and there is exhaust.
Depends on the model and what version of RF it appeared in as to what you will see, and what you can do about it. If RF 7.5 warns you about the model not being up to date when you select it to fly, you've got a model that probably spews great amounts of exhaust (not smoke). It may or may not have smoke as well. If it has smoke, it will probably be controlled by the Ch.7 (smoke/retract) switch. Flip the switch, and you may or may not be able to tell much change in the cloud being generated. It will probably still be pouring out way more exhaust than most glow engines can give even when too rich to fly.
What you've got to do is edit the model data to knock down that exhaust. Unfortunately, it's not a real simple deal as there are a number of different data configurations. You've got to deal with data in the fuselage folder. Within the fuselage folder should be an engine folder and then..... in there may be either an exhaust folder or a smoke folder.
I've dealt with 3 or 4 so far and what I found varied so that I wouldn't pretend to try and draw a flow chart of how to fix whatever it's possible to encounter.
Best for me to only suggest where to go to fix the exhaust.
da Rock is offline
Old 01-21-2016, 10:09 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
da Rock,
My 7.5 gave me a prompt saying that there was a more recent version to mine available and after doing the upgrade as you suggested the exhaust smoke went away. Thanks again.
karolh is offline
Old 03-15-2016, 07:13 AM
waynem
My Feedback: (58)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Karolh, I have the RF7 and on it the smoke is turned off and on with the mix switch. Wayne m.
waynem is offline
Old 03-15-2016, 10:05 AM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your response Wayne as the smoke on my sim is back with a bang. Where or what is the Mix switch you referred to??
karolh is offline
Old 03-15-2016, 02:51 PM
waynem
My Feedback: (58)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Karolh, On my R.F. 7 the smoke turns on and off with the top back switch on the right side. On my JR 9303 radio that is the mix switch. On the RF 7 the gear switch opens and closes the canopy if the plane has one. It operates the landing gear if the plane has that. Hope this helps. Wayne
waynem is offline
Old 03-15-2016, 08:21 PM
karolh
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Got it and thanks....smoke is now OFF.
karolh is offline
