Go Back  RCU Forums > RC Airplanes > RC Flight Simulator Software
Reload this Page >
Putting Simulator Screen on TV
RC Flight Simulator Software Discuss rc flight simulator software here. Aerofly Pro, RealFlight G3, XTR, Reflex, etc.
Old 12-26-2017, 06:18 PM
BalsaBob
My Feedback: (24)
Default Putting Simulator Screen on TV
Can the sim screen be put on a TV ? Can you run the sim on a laptop and then run a cable to the TV .... is that the best way ?
Thanks. Bob
Old 12-27-2017, 08:06 AM
rgburrill
rgburrill's Avatar
You can buy a cheap VGA to TV converter but the picture quality is not that great. You can also use Plex. I've done both an Plex is much better.
Old 12-29-2017, 11:48 PM
skylane_182
I run Realflight on my 55" 4k tv all the time. It draws a great crowd each year at the local airshow. If your pc/laptop has HDMI output that is the easiest way.
Old 12-30-2017, 03:54 AM
BalsaBob
My Feedback: (24)
Thanks for all the replies !
Will a laptop have enough power to run it well .... or do I need a desktop PC that has a dedicated video card ?
Bob
Old 12-30-2017, 05:02 AM
BarracudaHockey
BarracudaHockey's Avatar
Depends on the sim, RF-X probably wont even start on a laptop.
RF8 will run ok depending on the horsepower of the laptop and the realism settings in the sim. I have a fairly new laptop and run the sim on my big screen with an HDMI out.
I want to try it on the 8K tv's downtown
Old 12-30-2017, 06:15 AM
BalsaBob
My Feedback: (24)
Thanks. I plan to go with RF8.
Do you lose any capability, or is there any control input delay, with a wireless setup for the transmitter ..... or is the use of the cable between the transmitter and the pc/laptop better ?
Old 01-28-2018, 11:54 AM
acerc
acerc's Avatar
All your doing by using an HDMI output to a T.V. is using the T.V. as a monitor, no extra power is needed for the laptop to operate. I run my RF 7.5 on a 55" flat screen T.V. mounted on the shop wall via an HDMI cord. Work's great!!! A smart T.V. can be used wirelessly but there is a lag in the feed between the LT and T.V., at least mine did. I have not noticed any difference in RF's ability with any controller type's input, that being the Interlink, my radio connected, or my radio connected wireless.
Old 03-10-2018, 10:25 AM
Cadmandu
Default My Samsung says can't initialize direct 3d
Rf8 working good on my computer monitor anyone know what is wrong
Old 04-02-2018, 12:33 PM
Bandetx
Yes, it will work.
However, you should be aware that most large HD TV's aren't suitable for gaming as they have input lag, which basically means a delay. They willl not have 120-140 hz displays, which can make it look worse and potential graphical flaws. They will not support gsync/vsync so you might experience screen tearing.
