Just got AFP and need some help!
Hey
After watching the 2 videos of Maarten De Moor I decided that I need it so I got it.
Anyway, Im having some trouble with the planes. The roll rate is really slow compared to the videos Ive seen (not just his). On the Extra 330s, it will not do elevators and walls at all.
Is it because I need to setup my planes, dual rates (how do I work these?) or anything?
If its the setup, where can I get the setup that that guy uses?
Thanks in advance
Thanks in advance
RE: Just got AFP and need some help!
I have a 5 channel radio (one button).
How do I set this up?
Where can I get the setups that Maarten De Moor uses?
Moderator
My Feedback: (58)
Set your dual rates on your radio. Then calibrate in AFP with your radio set on high rate.
This is Maarten's setup for the Extra in the video :
Throws: all 60° except rudder= 50°
CG: +3.0 cm
eng: 12 kw, torque: 40%
prop: 31x10.6 max rpm= 8200
gross weight= 15900g
Change the 7.0 in the first column to 3.0 for the cg
As for the weight, just reduce the fuse weight by 1 kg.
Enjoy !
CG: +3.0 cm
Enjoy !
