Trim Schemes fm G2 Swap site
I downloaded several aircraft for G2 swap page but after intelling them on my simulator found that the trim schemes does not show as they should (or at least not the way they look on the website)... they just show the same trim scheme as the ones that come originally on the simulator... Anybody knows how to make them look as on the G2 swap page?[]
RE: Trim Schemes fm G2 Swap site
Hi Jcaz72,
First of all did you download the trim scheme off the site?
If you didn't You will have to find the aircraft again.
When you do at the very bottom of the aircraft description it will say (example) This Aircraft was submitted with the Michael's Fun-Fly Hots trim scheme Click on trim scheme then download and install it to your computer.
Once you've done that or you already have, start realflight and in the aircraft selection screen directly under the list of aircraft you will see the word regular with a down arrow.
Select the trim scheme and click ok.
It should have the new trim scheme.
Chris
Chris
Chris,
Thanks... I took a quick look at the G2 swap site and now I know what you mean... I will find the models again and then will download them tonight and I guess everything will work just great.
