My Screenshots
My Feedback: (21)
NY
RE: Giles Screenshot
Hey Ned you digging follow mode?
You know you can adjust the strength and view field of follow mode right?
Once you get that Shocky dialed in you'll be going in and out of them doors with ease.
It's also easy just to knife edge out the door too.
Try going down the stairwell in the gym. GOOD LUCK!
Yeah the folow mode is the only way to go for exploring in the gym. My 10 year old daughter likes it because she can fly all over the world with ease and just check out the scenery in all the different airfields... I didnt know, I will have to look into adjusting follow mode and see what I can do...
Im going to go check out that stairwell..
PS, That Giles is the easiest plane I have ever flown. It absolutely will not stall...Also it acts like its about 5:1 on power to weight,, its fun though. The Cap 232 is the most realistic flying of all the planes to me,,, Just like it is, it flies and performs almost exactly like my 30% Lanier Edge.
My Feedback: (21)
NY
That 40% black Extra 300 is the most realistic plane I've seen on the sim to date.
Takes some skill to 3D. It never was initially designed as a 3D machine, but making it do 3D sure is fun!
The Corsair free dload is prolly a close 2nd if not tied.
Hey Ned you need to install the OMP planes if you really want to have fun! 79" Yak is a blast.
Yeah, the black Extra is a little tougher to fly. I only flew it with the stock throws and it felt like more of an IMAC plane, really graceful. I will crank up the rates and give it a go,,
I have already downloaded them all, the OMP Planes that is but I have only installed the Bipe. I really like it, flies like a real profile plane. I will probably download the big Yak tonite or tomorrow if the weather isnt good for the real thing..
I LOOOOVE this one... AWESOME plane..If it flies like this in real life Id like to have one soon... I have been at it for 4 hours with this one.. Gotta be on your toes to hover it but it hovers well .. I think the trick is I need a high elevator and maybe 45 degrees rudder. My high rate rudder is on the stops, its just too touchy as I have it now. Im going to play with the rates,, but none the less its a great 3D plane.. Does great rolling harrier circles and 1 roll roling circles as well. My absolute favorite manuever with it is a low wall into a 3/4 waterfall that just barely clears the rudder and then into a rolling harrier circle starting from inverted, It doesnt want to stall when you push it over sharply and comes out level inverted so you dont have to fight it.. Me likey...
My Feedback: (21)
NY
RE: My Screenshots
The OMP Edge Hybrid is the best wing loading of any 92" plane in the world. You could not snap out the real one if you tried, it's too light. 92" wingspan and about 15lbs. That plane flies perfect, believe me I know. So does the 80" Edge.
