large Cap 232 for G2
My Feedback: (7)
Can anyone help as to where I can get a large scale Cap 232 for the G2 sim. I had one and lost it when I changed my computer.
Thanks in advance.
Roger
Thanks in advance.
Roger
My Feedback: (7)
RE: large Cap 232 for G2
ORIGINAL: cfossa
Roger,
Did you try the G2 download site? If I remember correctly you can download one there.
Carl
Roger,
Carl
Roger
NC
If you haven't checked there already then there is a Cap 232 there on I believe page like 4 or 5. I just don't know. Acutally there are alot of Caps that have been put on there. One is under the BIG cap (or something like that) and then you have the other smaller, electric ones. But obviously you don't need that one.
Hope this helps
~Michael~
Hope this helps
~Michael~
NC
You are most certainly welcome there Roger. I love that site. I don't know if that is the certain one that want because it is set up like 3D or something but I know it's large scale and that's what you wanted.
But you are very welcome. If you need anything else then don't hesitate to ask
~Michael~
~Michael~
NC
If you want to do an inverted flat spin then
Go up a little ways and start to go down
Then you cut the throttle, RIGHT rudder, LEFT aileron, and down elevator.
So, your left stick should be bottom right, and the right one should be top left.
You can play around for a while and add some throttle, keeping that right rudder and also letting off the left aileron and going toward the center. I just play around until I get the spin to where I want it.
If you want to to a blender then you go up (this is the way I do it), do LEFT aileron and then slam the sticks to the positions stated above.
If you want to do an upright spin, which I can tell you doesn't work that good with many planes, in the sim or real life, then
Go up, cut throttle do left rudder, up elevator, and left aileron for a left spin and for the right one, then you do right rudder, still up elevator, and right aileron.
I really drew that one out, and I'm sorry if I made it too wordy.
Hope that helps
~Michael~
Hope that helps
~Michael~
My Feedback: (7)
NV
you can go to the edit aircraft page and then on the page were it shows your aircraft to the left is little thing thats says Visual Scale then under it, it will say something like 84 in., you can just hit up, up to 200+in.
