Reflex scenery downloads?
OR
Which directory do I put the sceneries in for Reflex, I've got some planes from rc-sim.de and found quite easily that the planes go in Flugzueg or something like that, but where is the scenery supposed to be?
Thanks, Matt
Thanks, Matt
RE: Reflex scenery downloads?
Hi More Hp
they go in the scenery folder.
ahhhh sry miss read the above ide like to now that as well coss its in german init.
You go to the "umwelt" folder and find the "wlp" folder, that's were they go. Some of those scenery's you download, you have to make a new folder in the "wlp" folder and put your download in it. If your download wont work, you have to change the jpeg image to bit map, then it should work fine.
That's one of the downfalls I found with Reflex, it takes a little bit of screwing around to figure out how to do it, but once you figure it out, it seems pretty easy.
