esky transmitter and simulator problem
I know this topic has been posted a few times but I have not come across anyone who has the same problem
im trying to get my esky 3d transmitter to work with FMS.
Ive done everything you are supposed to do. I use PPJOY and it picks up the signals from the transmitter on com 2, then i run FMS controller settings and again there it recognises the movement of the sticks, but the when i go to fly the beast it does not seem to pick up the movement of the sticks even tho the controller calibration on the programe picks it up. I have also tried the interface cable with realflight G2 (non interlink version from a friend of mine) and again the programe picks up the movement of the sticks in the calibration menu, but the aircraft do not. .....im thinking that there has to be a simple solution. I usually find out why things dont work but this is just silly!
is there anyone who can tell me what the ... is going on
RE: esky transmitter and simulator problem
You have to keep PPJoy application running, just minimize it but not exit it completely.
If this doesn't help, you may want to order a CCPM cable for ESky "Channels Six" transmitter from www.milehighwings.com, which will let you use your TX (it's "Channels Six" model, isn't it?) with FMS and without any drivers like PPJoy.
I hope this helps,
Boris
I hope this helps,
Boris
i keep ppjoy running. I have two sound cards on my pc which means two game ports. Ill disable one and try it then.
ORIGINAL: giles25
