G2 edge 540 help
My Feedback: (15)
G2 edge 540 help
I've done a lot of different things to keep the G2 edge from rolling out on waterfalls with no success. I lightened the plane, reduced the taper on the trailing edge of the wing, lengthened the wing , but on the bottom it rolls out, and harriers are very unstable. anyone solved this problem?
Thanks.
Thanks.
My Feedback: (15)
G2 edge 540 help
Yeah Its awesome. I have all of the add ons and the edge is definatly the best. I read a post where a guy used the 0013 airfoil on the tail for knife edge, I tried it and I can actually do a wall now. The plane does have better characteristics with it. It still won't harrier good or waterfall. now i just need to figure out how to make a scheme for it like my 29% edge.
My Feedback: (21)
G2 edge 540 help
Send me pics of your 29% Edge and I'll make it for you! Visit www.Aero3D.net to learn more.
My Feedback: (15)
G2 edge 540 help
Well i finaly made one thats good but not perfect, BADGE if you go to aeroworks web site to customers pics, then edge 540 my main picture is the purple and white one with me holding it. click on it and there will be a few more. Quality isn't great because I didn't set the scanner up right, but should give you an Idea for the trim scheme. My name is Brian Sauers thanks alot!!!!
VA
G2 edge 540 help
edgeflyer, try making the cord of the wing larger.
I have mine out to 42" and now can do harriers walls and the like.
I haven't gotten good waterfalls yet but the larger cord helps with the high alpha flight.
I have also tried it on the cap x2 from the realflight site and it made a huge difference with that one, no more nasty stall, it just mushes along with the ailerons remaining very effective.
Lou
Lou
