What are your favorite G3 3D planes?
WI
What are your favorite G3 3D planes, ones that fly like you were flying real R/C planes out doors and what if anything did you do to make them fly well? For example What did you change, things like C of G or torque effect and/or sim speed, Elev. rudder ail. max throws etc.?
I modified the "Yak 54 with 3d throws" so it flies like my R/C plane by reducing the "back torque to about .40 and moving the C of G just a bit farther back and Increasing the elevator and rudder throw about 20%, also set the sim speed to 120% and added 1% right engine thrust.
Using JR radio with throws set to max in transmitter.
WRK
WRK
ON, CANADA
RE: What are your favorite G3 3D planes?
I like Rick's Extra 330s, not the Red Bull, or 3D version, just the normal one that is supposed to be for IMAC. I edited it just little by increasing the throws on all surfaces to 60 deg. I also put a hugely overpowered engine on it so that it hovers at about 4 clicks of throttle. It is really easy to do almost any maneuver, yet it still flies like a real plane.
MO
The TOC Ultimate!! LOVE it. I increased the throws a bit, tapped the cg back a hair, made it a tad bigger, Oh yes, and I made the ailerons ALOT bigger.... they just arent very effective in high-alpha flight in stock form. I'm not sure where i downloaded the model, but if i see it again, i'll let you guys know
