G3 Doesn't have enough rudder authority
FL
hey I have had g3 for abot a year and a half and i noticed that the planes do not have much rudder authority. i have tried kn loops but i can't get them to be tight. what is going on here?
RE: G3 Doesn't have enough rudder authority
aiecraft
go to edit
airframe
click on fuse
click on vertical stab
then rudder
click on max defection
and add more through
"ex"
before
max def 30
min def -30
after
max def 55
min def -55
38
go to edit
airframe
click on fuse
then rudder
"ex"
before
max def 30
min def -30
after
max def 55
min def -55
38
ND
Also try adjusting the weight of the tail sections etc or moving the battery,fuel tank around a little and readjusting the CG afterward. Thsi works great.
ND
Also try adjusting the weight of the tail sections etc or moving the battery,fuel tank around a little and readjusting the CG afterward. This works great.
