Frame Rates
Frame Rates
I know this question has been asked before but I cannot seem to locate the answer. How do you display the frame rate you are running in G2 or any game for that matter? Thank-you in advance. :spinnyeye
Frame Rates
Every game is different.
I'm sure there is another way on getting fps for this game, but you can use a utility called fraps19A.exe for any game. It's quite simple to use.
http://www.fraps.com/download.htm
My Feedback: (19)
Frame Rates
G2 has a built in frame rate display.
To set it up,
click on VIEW,
slide down to GADGET,
click on EDIT GADGETS,
click on the ADVANCED NAVGUIDES tab,
scroll way down the list to find SYSTEM: FRAMES PER SECOND,
click on the square box to put a checkmark in there,
click on the OK button to save.
To get the frame rate to appear on the screen,
click on VIEW,
click on ADVANCDED NAVGUIDES.
Or just hit the number zero key.
(note: the zero key on the calculator keypad won't work.)
To set it up,
click on VIEW,
click on VIEW,
