new G3 update suggestions
Well, as the .430 update for G3 has been well tested, I've noticed a few things that could be improved.
(1) After the plane hits a certain speed, it freezes and falls irregularly to the ground
(2) I would like collisions to be possible in multiplay. I think that the host should be able to turn it off and on though. Maybe the indevidual pilots.
(3) when a plane weighs around 150-200 pounds, you can't land without the prop cutting off.
Anyone else have any suggestions?
VA
RE: new G3 update suggestions
yea I have a few in my order of importance:
1. Fix the ground handling and add shock support to landing gear. Ground handling is the worst aspect of the sim.
2. Also get water support for float planes and hydros
3. Fix the problem with trying to create a twin engine electric with separate speed controllers and power systems
