hovering on G2
My Feedback: (33)
hovering on G2
what plane are you guys using to practice hovering with on g2 , i have all the add ons and none seem to hover very well. i downloaded the biplane from the g2 webpage and yes it will hover but , you can't stop it from torque rolling . any body ahve a plane that will hover good ? and would maybe like to share it
thanks
Chad
thanks
Chad
hovering on G2
I and others tweaked a Cap. Flys as close a real model as any sim plane I have flown. It will torque but so will about any plane at vertical.
Try setting the torque factor way down and try to keep the Bipe from full vertical.
Mike
Mike
SD
Hovering G2
Go to the real flight.com swap section and down load the Aeroworks Profile it's another good hovering Plane. there are also many diff. color schemes to choose from for this plane.
My Feedback: (19)
hovering on G2
The only G2 plane I've found that will truly hover with the nose vertical is the Harrier....since it is the only one that still has roll control in a vertical hover. Every other G2 plane will start torque rolling, and you can't stop it since the ailerons are useless in a G2 hover.
hovering on G2
there is one out there called Super Extra Special and it hovers great and doesnt tend to torq like some of the others. its either on real flights page or on the aero3Dnet web page....Gator
My Feedback: (33)
hovering on G2
well i figured out how to stop the planes from torque rolling, the cap 2x is not a bad plane to hover. if you want a plane to stop torque rolling go to the edit page , edit the engine and go down to where it says torgue value, and set to around 30% , there is 2 toruqe values on the edit page on is the actual torque value of the engine meanig stump pulling power the other is the rotational value but if you play with it you can actually get to roll the wrong way. its really hard to torque roll to the right .
i hope you all can understand what i wrote . lol.
Chad
