G2 not working
G2 not working
There are a number of DirectX example and diagnostics programs included with G2. Look in the "RealFlight Control Panel" under "Technical Support" . I would try running them to see what happens and take it from there. Maybe it is DirectX or your video driver that needs to be updated.
Krister
Krister
OR
Turn off the fog!!!
I had the same problem when I installed mine. It has something to do with ATI video cards. Go to the Airport menu on the upper left of the screen, and uncheck Show Fog, and I bet it will work after that.
Dan
Dan
G2 not working
Try turning off the fog. I don't know why, but they loaded the fog as a default. I always had to click mine off as I had the same problem until I got all the glitches worked out.
