Correct Walkera TX FMS sim setup
If your having problems setting up your PPM Walkera Tx check this out. (This assumes you are using the mic interface) If it calibrates fine but it won't work correctly in FMS try this configuration...go to controls -->analog control-->highlight joystick interface and click mapping/calibration. Then on the mapping side conifigure as follows:
Channel Inv Exp
Rudder 1 x
Elevator 3
Aileron 2 x
Throttle 4
Tail 1 x
Nick 3 x
Roll 2 x
Pitch 4
This is the setup for the Walkera 22e Tx, but I would imagine is valid for most if not all others.
Channel Inv Exp
Rudder 1 x
Elevator 3
Aileron 2 x
Throttle 4
Tail 1 x
Nick 3 x
Roll 2 x
Pitch 4
RE: Correct Walkera TX FMS sim setup
About Walkera compatibility:
http://www.milehighwings.com/faq.htm#10
