Phoenix Sim Heli Help
I just received my Phoenix Sim and I can't get the Helis to lift off the ground. It appears that that the blades are pushing up instead of down and I can't find anyplace to switch the settings. Please help. Thanks
MA
RE: Phoenix Sim Heli Help
Look under the System menu, and click "Your Controls". Then click Configure to configure your controller. This will let you assign channels to specific controls, and reverse any channel. This should all be covered in the Phoenix RC manual. If you've upgraded to 1.03 (free update on the phoenix rc website), then the manual is accessible under the help menu. Otherwise look under the PhoenixRC Start menu folder for the manual.
I have upgraded to 1.03 and have looked through the manual and I know I can reverse the channels but when the Helis are throttled up they just clamp tighter to the ground. I think that I have to somehow change the rotational direction of the rotors and thats what I can't find how to do in the settings. Any info. would help. Thankyou
Curt
Curt
I got the helis working. I had to assign the collective pitch with the throttle channel. Don't have any extra channels on the transmitter that i'm using (JR XF 421EX) Thanks a lot guys.
Curt
Curt
