New Model Extra300s for Aerofly Pro
ON, CANADA
Hi, here is an Extra 300s for AFP I made that I figured I would put on here for other users to use also.
around 90" wing span. The textures are nothing fancy but it flys fairly good.
To install just unzipp and make sure the files extract to a folder called Extra300s, it should unzip into this folder but just to be sure. Then just place this folder into "Ipacs\Aerofly Professional\Aircraft\"
If you have any troubles with it please let me know.
Download here
Download here
ON, CANADA
Did you unzip the file you downloaded first? If so double check that the all the files showed up in a folder called Extra300s place that folder in the aircraft section of the game and it should work.
