U-can-do realistic in g3.5?
I cant do squat with it in the simulator... hard as **** to hover it and do torque rolls... I enjoy flying the yak 54 so much the same flight simulator so I ask whether the u-can-do physics resemble real-life.... Or maybe that the yak 54 is too easy to fly and do things ... or maybe because the yak 54 is bigger (dunno how much though)...
Other than that you could recommend me a nice cheap 3d model for my OS 55ax ....
cheers ! !Peter
cheers ! !Peter
RE: U-can-do realistic in g3.5?
I've played with the UCD in G3 and believe me, it's easier in real life. Configure your ailerons for flapperons and scoot the CG back about 1/2 inch from the Mfgr recommendation and it will fly as docile as you want or you can let it rip. The secret to these planes is to keep the speed down, They're not meant to go fast like the YAK, Edge or Extra - completely different airfoil.
I had better luck with a 12X5 than with a 13X4W. The 13" prop was a bit too much for the .55AX.
