Real Flight Deluxe
Real Flight Deluxe
I bought a used Real Flight Deluxe sim. But can't get it to work. When I down load, it ask's for a number off the the transmitter. But there is no number on my transmitter. This is version #1.20.111 and I have the serial number.
Can someone help me out here? Sure would appreciate it.
Thanks, Bill
Thanks, Bill
Real Flight Deluxe
What do you mean "When I down load"?
Is it asking you the controller number when you are trying to install the software?
Try installing it without this number. For RealFlight G2, only Serial Number of the software is needed--you can install it without any controller or interface number and then configure your own controller (like a TX-to-PC interface from www.milehighwings.com)
I hope this helps,
Boris
I hope this helps,
Boris
FL
Real Flight Deluxe
I have the Deluxe Version with the gameport transmitter that came with it. When you install realflight, it asks you for the software serial number and then it asks for the "interface" serial number, IF you purchased one for your normal transmitter. The TX that came with the simulator, on Deluxe at least, does not have a number, so I just leave it blank and it's fine.
