afpd no calibration of 6exa or 4exa
Hello,<o></o>
I’ve recently bought an AFPD with version 1.11.7.9 and installed as per manual. When I get to calibration, the window tells me that AFPD has located the usb interface cable but was unable to either find a Tx connected to usb interface or a joystick. I’ve tried two txs (futaba 6EXA and 4EXA) with appropriate square ‘micro’ adapter, but no connection as yet. Any help please? <o></o>
Thanks<o></o>
jeppy
Moderator
My Feedback: (58)
RE: afpd no calibration of 6exa or 4exa
Hi Jeppy, thanks for the photos. The adapter cable that you have is not the correct type and is in fact not from Ikarus. It is most probably causing a connection problem between the radio and usb interface cable. It is recommended that you use the 31036 or AFP-01 adapter cable.
ok then. i'll try to get a new one and when i'll try on i'll let you know. might take a few days now.
thanks so far.
thanks so far.
