RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Can E85 give more power in a DLE-55?
Reply
Old 01-10-2011, 11:06 AM
wingspan99
wingspan99's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Can E85 give more power in a DLE-55?
I know some people have used methanol on gassers in the past and got more power. Would E85 give more power and what oil and ratio should be used? I'm assuming a synthetic oil should be used so that it blends well with the E85, but with the lower lubricity of the ethanol at 85%, I should probably use more than 1:30 oil/E85 mix. Anyone tried this?
wingspan99 is offline
Old 01-11-2011, 05:22 AM
gkamysz
gkamysz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Can E85 give more power in a DLE-55?
You aren't going to see more power with E85 unless you increase compression ratio to take advantage of octane rating. The lubricant needs to be compatible with alcohol, castor or synthetic. There aren't many choices for lubricant, Klotz KL-200 is one I've used. Oil ratio is a good question, let us know what you find.
gkamysz is offline
Old 01-11-2011, 07:25 AM
jeffie8696
jeffie8696's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An old article but a good place to get started. http://journeytoforever.org/biofuel_...nol_drane.html
jeffie8696 is offline
Old 01-11-2011, 11:04 PM
Kweasel
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I know people in Florida that successfully ran 20:1 KL200 in their Sachs 3.2 and 4.2 when burning methanol. Dont know how low you can go but tipping the can never hurt. Try a full length tuned pipe with E85 for insane power.
Kweasel is offline
Old 01-12-2011, 06:55 AM
wingspan99
wingspan99's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have a .61 size pipe, would it be big enough for a DLE-55? I know the DLE runs at half the speed the .61 used to run at, but the opening is very small. Any suggestions on a pipe for the -55?
Old 01-13-2011, 11:46 PM
TimBle
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
you will need one of the "canisters" for a DLE55. These are specially designed for gasoline engines and takes advantage of the massively increased gas flow that a 55cc engine has and lower rpm.
The engine porting and hence timing on the DLE is optimised for gasoline so E85 is going to give you no gain, you will have less power. It may burn faster but it yields a lower temperature of combustion which also means possibly increase friction since the engine block will reach its design temperature.
well thats my 2c
TimBle is offline
Old 01-14-2011, 01:18 PM
Sport_Pilot
Sport_Pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Actually there will be some power increase, just not as much as if you raise the compression ratio. The same can be said for methanol, but E-85 power increase will be moderate compared to methanol.
Hot rodders have found that both ethanol and methanol will increase power with no mods. Cam and port timing are related to the RPM that peak horsepower and torque are required, not the fuel. The fuel increases the combustion pressure which increases torque at this peak thus also increasing horsepower.
I think the confusion is because of efforts to regain some economy when running E85, increasing compression increases power and economy. But only moderate fuel economy when using the max power, so timing is altered to decrease power and to produce power at a lower RPM thus increasing economy.
Sport_Pilot is offline
Old 01-15-2011, 07:26 PM
wingspan99
wingspan99's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I have mixed some E85 with 10% castor mixed in and I'm going to try it. I know the castor isn't the best oil for a gas engine, but it blends in the E85. I have some KL-200 too, I'm going to try mixing 6% KL-200 in E85 and see what rpm I get compared to 30:1 gasoline.
Old 01-29-2011, 01:19 PM
moe7404
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
what this cat has is a project car. if he was driving a daily driver he wouldnt have as a glowing report. also some of his info is wrong. also i have worked on and owned LOTS of that carb he used , on scale of 1 to 10 that carb is a 3. that carb is good ONLY if you know how to work on it, he doesnt.
moe7404 is offline
Old 03-20-2011, 01:32 PM
moe7404
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i dont know what i was thinking on post #9 it looks like i posted something on this thread that was realy for somewhere else. sooooo, thats my mistake for the year , sorry
moe7404 is offline
Reply
Display Modes
