Fuel mixing advice
#51
RE: Fuel mixing advice
hi
thought about mixing fuel many times-the problem is you have to buy in large quantities for the price to be justified-so then you have storage issues -not for me !
i read that if you buy enough nitro you will be hearing from some government agency due to a possible terrorist issues i am paying 17.00 a gallon for 15% at the LHS so just not worth the trouble to me been using MORGAN OMEGA in my two cycle glo engines for 18 of my 20 years flyingthe stuff keeps my engines new internallycan not remember the last time i had to change a bearing in 18 years
BEST REGARDS TONY
BEST REGARDS TONY
#52
Kero, A quick test is what I'm after initially. That way I don't spend the 33 and 23 for material Idon't know if I canuse. I picked up the S-L-X about 1/2 hr. ago. Still need a #6 plug.
#53
ORIGINAL: TCraft Lover
Kero, A quick test is what I'm after initially. That way I don't spend the 33 and 23 for material I don't know if I can use. I picked up the S-L-X about 1/2 hr. ago. Still need a #6 plug.[img][/img]
I guess this is a hobby, so "seat of the pants" evaluations are what we go by. But it would be nice....
#54
If it runs well with the denatured alcohol it will definately run well with FAI fuel. Carb settings will be the same too. Well you might have to richen the high speed needle a click or two, at least that's what happened with my OS .25 LA.
Good luck.
How is the compression on that engine? With my ST .40, it's like the ring never really seated well and it still has very little compression. However, it runs very well and with great power too.
#55
ORIGINAL: hsukaria
Speaking of glow plugs, I wish that there were a universal listing of all brands and models' temperature range so that you can compare temp. ranges across the board. We know within a brand what is hotter, but between brands, we don't except by experience. But who is going to buy all the brands and models and evaluate that?
Kero, A quick test is what I'm after initially. That way I don't spend the 33 and 23 for material Idon't know if I canuse. I picked up the S-L-X about 1/2 hr. ago. Still need a #6 plug.[img][/img]
#56
Kero-
The ring is well seated and I gotta say that this is the coolest sounding engine to just flip over by had. Easy starts too, just a back flip against compression and she goes. I'll try to post any info I come up with. How does 2 oz of castor and 8 oz of S-L-X sound for a ratio.
Dave
#57
Kero-
Dave
Kero-
Dave
#58
ORIGINAL: hsukaria
TCraft, no experience myself with these big 2-stroke glows, but I believe that the large ST engines require LESS oil. Maybe 20% might work ok, but I was told by other owners that they are designed to run at lower than 20% oil. I don't know how much, but I suspect the ST manual will say.
Kero-
Dave
Kero-
Dave
#60
Not a problem. These Tigres can get kind of confusing. My manual covers all of them from the G34 ot my G2300.[img][/img]
#61
Kero-
Dave
Kero-
Dave
That ratio sounds perfect. Can't wait to hear the results.
#64
Keropower-
Is your .40 a ringed engine? Say what you will about ringed motors not making the power but I still love'em.
Keropower-
#65
ORIGINAL: Sport_Pilot
Those that do are confusing Silicone with Silicon.
There are a lot of people that say AA will kill glow plugs,
Continuous burning decomposes the silicone oil and silicon the element deposits on the glow element, glassing it over and fouling it. It doesn't happen overnight so you are safe for a few gallons. By the time it happens you should probably change the plug anyway, so you've lost nothing in the end
#66
Yes the my little ST .40 is ringed and it makes great power. I have also noticed how when the engine is hot, compression is very low. When cold it has more.
I hope I didn't mess up the break-in. But the general rule of thumb (according to my glow engine book) is that with ringed and lapped engines, one knows when they are broken in when they can hold peak power for 30 seconds without sagging. My ST .40 will do this, but it doesn't have very good compression. So it's broken in, but not really?
Anywho, I'll just keep running it.
When I broke in my ringed Magnum .52 four stroke, compression camp right up during break in. It now has diesel like compression. But the exhaust valve leaks very slightly. I think I just need to adjust the valves though. Not much if not any clearence between the rockers and the valves.Very tight.
#67
ORIGINAL: KeroPower
#68
My Mag is not in a plane right now. It's my only 4s right now. Well I did have a Mag .30 and it ran ok, but both valves leaked horribly. Even tried lapping them with lapping compound and an electric drill. Still leaked. But I now realize it is the guides. They don't really guide the valves straight up and down. Valves kind of wiggle. So it is impossible to get a good seal.
The Mag .52 runs well for me. When I had it flying, I was using Omega 10% and an OS F plug. But you know quality varies with these cheap engines.
But I don't really like the four strokes anyway. I'd take a smooth running OS LA engine any day over a four stroke. I know that sounds lame, but I just love the way my .25 LA sounds and runs with that mousse can muffler. It makes that "tinging" metallic sound like a two stroke dirt bike.
#69
Kero
To my way of thinking, if your ST 40 idles and has correct top end rpm then it's just fine. If it won't idle or overheats after a short period at max rpm then there could be a problem. I remember seeing old K&B engines sitting on the groundwith propsfreewheeling in the breeze. But as soon as they were fired up they ran great.
#70
ORIGINAL: KeroPower
ABC engines will have a slight compression decrease when warm, but should come back shortly after shutdown. (at least in my experience)
#72
I have 2 early style K&B Sportster .65 engines. Both were unrun when I got them, 1 still unrun. I debaffled the muffler and I've found these engines to have a unique set of sounds that you don't hear in BB engines. You wouldn't think an engine would run right making squeaky chattering noises, but surprisingly it runs well and swings big props nicely. Bad carburetion causes a really rich midrange, but that's easy to fix. Performance got better and compression got better on lower nitro all castor fuel.
#73
Yeah I'm sure no engine guru but it seems to me that SOME older engines and euro. brands do very well on low -no nitro fuel. That's one reason I'm heading out for a #6 OS plug this morning. I'm itching to do my Meth./castor test.
#74
I like using long reach plugs in engines that are supposed to use long reach plugs. Most OS plugs are short or medium reach. There are long reach OS plugs, but I don't know what they are off-hand since I don't use them.
Do you have to come to the cities to hit the hobby shop or is there a shop up by you?
#75
Yes I did exactly what you did to break it in. Rich four cycling and progressively leaned it out. The ring is all shiny now.
http://www.rcuniverse.com/magazine/a...article_id=400
Scroll down to the Wish List and he also mentions the soft compression.
