RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
How to keep castor from seperating in cold?
Reply
Old 01-16-2012, 07:21 AM
Max_Power
Max_Power's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default How to keep castor from seperating in cold?
Ok, I have some high nitro fuel I mixed for my small 1/2a engines for when I want them REALLY HOT . I had a jug of powermaster 50/50 methanol/nitromethane like they used to sell. I combined 8/10 of a gallon of this to 2/10 of a gallon of sig castor. I figure I should be pretty close to 40% nitro and 20% castor fuel mix.
Here in Minnesota when it is cold the oil seperates and rises to the top. I have read that with high nitro percentages the oil will seperate like this and unless you want to be constantly mixing it needs a "co-solvent" How normal is my situation and what can be done about it? What is a good co-solvent? I'd like to make this work as it will be all the high% fuel I will need for life running small engines! Thanks in advance.
Max_Power is offline
Old 01-16-2012, 09:08 AM
gkamysz
gkamysz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: How to keep castor from seperating in cold?
Typically the answer is synthetic oil.
How long has your castor been sitting around? I've had problems with old castor.
gkamysz is offline
Old 01-16-2012, 11:00 AM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Add some acetone. This helps as solving agent. Keeping the fuel above freezing when not in use also helps.
pe reivers is offline
Old 01-16-2012, 05:13 PM
downunder
downunder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I suspect your fuel is hovering right on the edge where castor is no longer soluble in nitro and I'm guessing this "edge" may be temperature dependent in that with warmer fuel the oil may not seperate out. Try what pe said or you could try ether which is a very good solvent but tends to evaporate out rather quickly. Or just fly on warmer days .
downunder is offline
Old 01-16-2012, 08:19 PM
Max_Power
Max_Power's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
How much acetone are we talking PE? 1 or 2%?....I did move it into the house out of the cold garage and it seems to be better. I don't use it very often but like to keep it as a "stash" of the stout stuff. The castor is about 2 years old, as is the nitro/methanol. Thanks for the replies...I think I may try some acetone.
Old 01-17-2012, 03:47 AM
pe reivers
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The norm is about 3%. More will harden your silicone fuel lines too much.
Because Acetone evaporates better than methanol at low temperatures, it also improves winter wonderland engine handling, especially the cold starts.
PS
Ether in glow fuel causes knock, unless your compression ratio is very low. Not good either way.
Old 02-11-2012, 08:01 AM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I heard a detergent mixes oil and water in high school chemistry.  I am not sure I would put it in glow fuel with a motor I care about though.  Most of them are water based.  Might be an experiment if you have nothing to do.  It may foam up too much or take too much to have an effect. ( I failed grade 12 chemistry too if you really want to know.)
aspeed is online now
Old 02-11-2012, 08:09 AM
Sport_Pilot
Sport_Pilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: aspeed
Our oil and fuel is soluble in water so detergent really in't required.
Sport_Pilot is offline
Old 02-11-2012, 02:21 PM
aspeed
aspeed's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Unless the detergent makes it more soluble so it doesn't separate.  I was worried about the water in the detergent ruining the motor.
Old 02-11-2012, 03:03 PM
Sport_Pilot
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: aspeed
No the detergent would not be any help. Acetone might.
Old 02-11-2012, 04:58 PM
Max_Power
Max_Power's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Acetone worked well...as did a slightly warmer storage area, Honestly I'd just shake it up right before I use it before I started adding anything too weird or water to the stuff. I think if it were any weaker than 40% It would'nt have done it? Todd
Reply
Display Modes
