RC Fuels Nitromethane, Castor Oil, Synthetic, heli fuel, 4 stroke, etc...Fuel Q&A is here!
Propylene Oxide
Reply
Old 03-16-2013, 08:59 AM
summerwind
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Propylene Oxide
anyone know where i can buy this?
used in our high nitro fuels for Free Flight produce a mule kickin' fuel.......
summerwind is offline
Old 03-16-2013, 09:47 AM
ByLoudDesign
ByLoudDesign's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Propylene Oxide
IF IT IS THE SAME STUFF USE BY AUTO RACERS YOU MIGHT START THERE!
ByLoudDesign is offline
Old 03-16-2013, 10:07 AM
Dave Harmon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: summerwind
Yep....go to race or fuel shops in Fresno. If they don't have it they will likely know where to get it.
I used it for years when I lived in the LA area but the EPA may have killed it.
It does not make more power but it DOES make engines easier to start and especially improves the idle when using cold or low nitro fuel....or FAI fuel.
If you find some prop locally do NOT add more than 1oz per gallon of mixed glo fuel.
It is very volatile and too much will advance the timing of a glow engine and cause detonation on a higher compression engine.
If you are looking for power....add nitro....not prop.
Eventually.....I switched to using acetone for easier starting and improved idle.
It's cheap and readily available anywhere.....unlike prop which was expensive....like $8 a pint back in the 80's.
Use acetone only 1oz per gallon but again.....it does not make more pwer....add nitro for that.
Have fun.....
Dave Harmon is offline
Old 04-08-2013, 08:56 AM
iskandar taib
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Red Max sells it. Or used to. I got a gallon of it from them in the late 90s. A friend decided that he was going to drop by on a detour (he had work in DC) and pick up a 30 gallon drum of stunt fuel. I'd found some free flight 1/2-A recipes in a magazine, he contacted Red Max and they agreed to mix me up a couple gallons. Lots of nitro, some propylene oxide, and a little amyl acetate if I recall correctly. I suspect they use these things in certain fuel mixes they make. Also had him bring back a gallon of propylene oxide while he was at it.
The Jet Speed people used to use it in Dynajets - the fuel they used was pure nitro, the problem was it could be difficult to ignite, so they mixed some propylene oxide in with it. If I recall correctly, they also ran a beginner's class, where the fuel was pure propylene oxide. Different rules these days, I forget what the mandated fuel is.
Iskandar
iskandar taib is offline
Contact Us Archive Advertising Cookie Policy
