Changing from 10% nitro fuel to 5% in an OS46
Going from 10% nitro down to 5% nitro will require a slightly leaner needle setting.
Did you try it? What did you think? My experience with 2-strokes is that going from 10% to 5% makes no perceptible difference. I tune my engines every time I fly, so I would not have noticed a difference in the needle. But my engines seem to have just as much power and idle the same on 5 as 10.
I used 24 gallons of leftover C/L Stunt fuel from 5 to 15% nitro and all about 20-22% total oil and can say the OS 46 AX is a great running engine with a great ability to burn about any fuel you put in it. Afer all of that flying it sounds as if it could use bearings!
Chris...
PS I had a 46 SF that was the same way, it died in a horrible straight in due to learning about battery charging and its necessity.
Chris...
On the other hand, does raising nitro affect piston cylinder fit on these AX engines if you already performed breakin at lower nitro - or a lower average cyl temp?
