Home-brewing fuel
#152
RE: Is there really a savings???
Haven't mixed fuel in a long time but planning too in the near future and have been shopping, the prices below is the best quote to date.
Methanol - $2.5 per gallon.
Nitro - $48 per gallon.
Coolpower and castor pre mixed oil $22 per gallon.
I can get Omega 15% nitro fue;l in this area for just under $16 per gallon so to mix it myself.
Nitro 15% = .15*48=..$7.20
Oil 17% = .17*22=.....$3.74
Methanol = .68*2.5=..$1.70
Total $12.64
If I buy 5 gallons of nitro I can get it for under $33 per gallon which would reduce the cost to $10.39.
Total $12.64
#153
RE: Home-brewing fuel
I was thinking about mixing my own fuel, but I don't even think it's worth it. My local club buys it in a 55 gallon drum with 10% and sells it for $10 a gallon to club memebers. Could you tell me if anybody can buy it cheaper or make it than that price?
#154
Ask Brian Cooper for a quote. I know his fuel is better than most, and his syn oil is superb. He might be able to match their price, and deliver a higher quality fuel.
Tell him Rick sent you: [email protected]
#155
OR
If your club is buying a drum, make sure they are putting the entire drum into one gallon bottles after the first tapping. If the drum sits around over time partially full after being exposed to air (and moisture) the fuel quality will degrade. The best way is to gather up a bunch of bottles, sealed after the transfer, and store them instead.
Dan
Dan
#156
My Feedback: (10)
CA
We go through about two 55 gallon drums of nitro a weekend. It always has a yellow tint in it as a indicator for contamination or additives. It WILL turn a color if contaminated (usually purple). I take the left over nitro in the bottom of the drum and transfer it to a good sealing fuel jug (5 gal size). As long as the jug is not subjected to temperature extremes and direct sunlight, I have kept and used it for as long as a year without any detrimental effects. The menthanol is a different story as it will absorb moisture from the air. Use it in a relatively short time or replace it fairly often. I have always used Klotz oil, full synthetic for blends over 15%, for over 2 years and have never had a problem.
Russ
Russ
#157
If you cap the drum after each use then there should be no problem using methanol over a long period. Even 55 gallons of air will not contain enough moisture to make a huge differance, though I would pour off the last 10 gallons or so into 5 gallon containers. A 55 gallon drum will hold only about a half pound of air. At 90 degrees and 100% humidity the moisture content of the air is only .03 pounds of water. So I don't see any need to hurry up to use the fuel.
#158
Cheers for that comment Sport_Pilot - I've got a month-old 55 gallon drum of methanol sitting in a back shed which I'm half way through (my mates are having problems getting enough containers to claim their share), but was starting to worry about moisture buildup. The humidity where I am is pretty low, and the tank is alwys sealed when not being emptied, so I'm guessing it should be fine for another month
#159
Yes, and actually I notice I made a slight mistake. The humidity ratio was actually .03 pounds of water per pound of dry air, so if a 55 gallon drum holds approximately 1/2 a pound of air, then there would only be .015 pounds of water. As long as you keep an air tight seal, you should be fine.
#160
Using this calculator:
http://www.overgrow.com/tools/rhumidity.php
And readings from our local weatherstation:
http://www.weatherzone.com.au/observ...&name=Canberra
I worked it out that over the last month the times the tank has been opened it has been fairly cool - around 13 degrees C (55F) and 46% RH, which equates to 5 grams of water per cubic metre of air. A cubic metre is 1000 litres, a 55 gallon drum is about 200 litres, so half a drum would have 100 litres of air, or 0.25 grams of water. 0.25gr of water is 0.25ml or .00025 l, so if all moisture was absorbed into the 100l of methanol, it would be .00025/100 or .00025% added water.
Obviously, if things were both hotter and more humid, the amount of water would be greater.
#161
My Feedback: (10)
CA
You guys crack me up! I'll bet you are all correct about the absorption of water in methanol, but everywhere that I have read about usages of methanol for fuel, it warns about leaving the container open. Personally, I would prefer to get rid of the methanol after a while and get some a fresh supply, especially since I pay less than $1.00 a gallon! It leaves one variable out of the equation.
#162
Hey, point taken, I'm not planning to marry the damn thing! It should all be gone in a month or so, but in the meantime I know I don't need to be overly concerned that the fuel is going bad, and of course I never leave it nor any other of my fuel containers open for more time than it takes to add or remove fuel.
But it does put in perspective exactly how significant the issue of fuel storage is - no-one wants dud fuel mucking up their tuning. This analysis gives me a yardstick for being able to confidently judge what level of care is realistically required.
In another post on this forum, "Downunder" progressively added water to his fuel in order to see at what point performance started to degrade. From memory he started seeing problems above the 3% level. I'm a big fan of scientific analysis and experimentation, so to me, with a little research on the net about humidity and his tests, I've got a much better idea of how water, methanol fuels and glow engines interact. As I said, it won't change how I behave, but it puts me in a better position to make judgements when I see problems.
Oh, and since this is a fuel forum, my current recipe: 15% Klotz KL200 Original Techniplate, 3% castor and 10% VP Racing nitro makes my 12 year old, twice busted ASP .40 swing a 11x6 prop at about 11-12k.
#163
#169
My Feedback: (7)
TX
ORIGINAL: DrV
I've never mixed fuel before but as I understand it you do the calculations by volume. In your case, by a gallon.
Well 1 gallon approximately = 130oz
2% of 130 = 2.6oz (castor oil)
18% of 130 = 23.4oz (synthetic oil)
10% of 130 = 13oz (nitro)
70% of 130 = 91oz (Methanol)
Add 2.6 + 23.4 + 13 + 91 = 130oz = 1Gallon
At least this is how I understand it. If I'm wrong someone correct me please.
Mike
Mike
#171
CA
Just a suggestion, if you have the methanol sitting around for too long, why not just use a bit in the auto, every time you fill up. Will keep the water from separating out in the winter. Cheap methanol is about the same price as gas, though you won't get the same MPG. Better than using it in your fuel and getting a crappy run??????, then go out and get some fresh stuff.
#172
My Feedback: (8)
MI
For the sake of simplicity (for me at least), and to get a 5% nitro mix, how about adding
20% of 20% premix fuel
15% oil
65% methanol
I know the %'s could be figured more exact but for this question these are ok.
Would this work properly?
I can get methanol given to me so that helps the cost factor.
15% oil
65% methanol
If anybody has not yet tried rsieminski's spreadsheet, you're missing out if you're a homebrewer of fuels. I have tried to find mathmatical holes in it and can not. It has some usefull tools in it for adding components to premixes, excellent tool.
I'll start monitoring this thread a bit closer if you guys have any specific questions that you think I could answer.
